Question about Gemini PT-2100 Turntable
My turntable has stopped spinning when i press start. when i stop it it spins back for a sec then nothing.when i take the plate off the turntable the bit that would spin seams like it can't move free is the motor broken or the brake stuck on ? i don't have a clue but i want it up and running again and i don't know who to see about it
    Brigadier General:
  • 8,546 Answers
Since it's Direct Drive there's no belt to fall off. There is an electronic brake.
Could your problem have something to do with the Reverse function? Check the L.E.D. Perhaps cycling it will help.
USING THE REVERSE BUTTON:
1. Press the REVERSE (17) button to reverse the rotation of the
PLATTER (2) (the REVERSE LED (17A) will light while in reverse
mode). Press the REVERSE BUTTON a second time to return to
normal play.
http://www.geminidj.com/disc._prod_manuals/TURNTABLES/PT-2100/PT-2100.pdf
Posted on Apr 04, 2009
2010 seat ibiza 1.6 sport sort of growling noise sometimes stoes for like 2 sec,s then starts again and stops when clutch pressed in.
indications are a failing throw out bearing for the clutch or clutch plate getting worn out AS the clutch plate lining wears , the pressure plate fingers come back closer to the throw out bearing causing it to spin
if you can make an adjustment on the slave cylinder push rod or clutch cable to give the bearing a nit more clearance the noise may not be there as it will not be spinning from the pressure plate fingers
Dec 16, 2016 | Cars & Trucks
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
The plate of my microwave own doesn't turn
Turntable motor must be replaced.
May 28, 2010 | Microwave Ovens
Turntable has stopped revolving... will start to spin as soon as START button hit - goes about half an inch and then completely stops.
One suggestion i would make is that in the microwave there is the turntable, lift the plate off ,then below it you will see a circular object with wheels on.I think you may have this the wrong way up, so turn it over put the plate back on top and should work.
its the circular piece on runners that is the problem
Oct 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Gemini PT-2100 Turntable Logo
379 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Don Hart
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
