Question about Linksys Wireless-G WRT54GL Router
Wrt54gl router firmware upgrade interrupted?
I tried to upgrade the firmware of my router wrt54gl from its factory firmware to ubiquiti firmware but it was interrupted before the proceedure completes and now i couldn't find the GUI settings of my router.Although, it gives the dhcp ip to my machine.But the power indiactor keeps flashing the light on and off. How can i see the Gui settings of my router? Do i have any options left to switch it back to factory firmware?Please help me!
  • 23 Answers
Try to reset it, by pressing reset button
Posted on Mar 07, 2009
Reboot after 10 seconds.
You have accomplished what is known as "bricking" your device. If anything interrupts a firmware update, in most cases the equipment will be unable to recover from it. It will require factory servicing to reestablish the firmware. It is usually cheaper to buy a new device. Remember this about firmware upgrades - just because one is available does not mean you should upgrade. Many devices will work forever without them. Unless you are in a situation where changing requirements of your equipment and/or providers means an upgrade MUST be performed, the best rule is "if it isn't broken, don't fix it!"
May 17, 2016 | Computers & Internet
I tried to upgrade the firmware of my router(WRT54GL) but during the upgrade process I got a message upgrade interrupted but with a continue button. I pressed the continue button, but the upgrade never...
Hi just switch it off and wait for 15 second turn it should come up hope you not disconnect the LAN cable or power cable from you router during upgrade otherwise your router maybe cant be use anymore but if it is stopped by it is own it could be wrong firmware version or incompatible one you have entered should you need any help please contact me via my weblog
Jul 22, 2011 | Computers & Internet
>>I'm having problem with my internet connection,\r\n-I already called my internet service provider to fix the problem but they told me that the problem is with the router, Directly connected to the...
the problem with wireless routers is that they only will put out little more than 1mbps it may say 54mbps, but it'll usually only download at about 1 mbps, ive found it frustrating myself, but thats all the firmware in those will allow, ive tried to upgrade mine, but still the same, there isnt a fix that i'm aware of, wireless "N" maybe different but i doubt it, sending that much information wirelessly creates alot of heat,
Sep 19, 2010 | Linksys Wireless-G WRT54GL Router
Firmware upgrade was interrupted & now I can't connect to it. I have reset it 3 times & still nothing
Upgrading the router's firmware will give it numerous functions. This includes a more stable connection to the internet.
To upgrade the router's firmware, complete the following steps:
i. Downloading the Firmware
ii. Backing-Up the Router's Settings
iii. Upgrading the Router's Firmware
iv. Completing the Firmware Upgrade
v. Restoring the Router's Settings
vi. Completing the Firmware Upgrade Process
NOTE: Before proceeding with the upgrade, your computer must have an active Internet connection. It is also recommended that you use a wired computer in upgrading the router's firmware.
Sep 10, 2010 | Linksys Wireless-G WRT54G Router
Xbox Live with Netgear WNR834M Router
please follow the steps to fix you issue
1.upgrade firmware on router
link for latest firmware
follow steps to upgrade firmware on router
1.Log in to the router using a Web broswer. The URL is ( if you did not change the router’s IP address ).
2.Click Maintenance > Router Upgrade
3.Click Browse and find the file you just downloaded.
4.Click Upload. Do not interrupt the upgrade while the router does this step. The router reboots when the upgrade is done.
5.After the router boots up, log in the router again.
6.You MUST Reset the router to default settings after upgrading the firmware
7.Click Maintenance > Backup Settings
8.Click Erase. The router reboots when the Erase operation is done.
9.If you would like to check that the upgrade was successful, log in to the router again at, and check the firmware version.
10Re-configure the router with the settings you saved in step 1. Optionally, You can use the Smart Wizard configuration assistant on the CD to reconfigure the router.
after all this login to router
under advance you will WAN setup there will NAT ,you need to click on open then apply
Jan 26, 2010 | NetGear RANGEMAX WNR834M Router...
I'm trying to upgrade the firmware on a belkin wireless router
upgrade of Firmware is at your risk...
never upgrade Firmwares....they are not ment for that....
your hardware may be rendered useless after firmware upgrades....the chip inside your hardware is programed to run based on a certian program installed as a firmware from the factory....sometimes upgrades will screwup your be careful and do it at your own risk...
Dec 10, 2009 | Belkin (F5D7230-4) Router (587009)
DWL 2700 AP wrong firmware install
since you upgraded a different firmware try updating the firmware again with the correct firmware if it works fine if it doesnot then the router had gone bad,,
and for GeminiBS reset the router to the factory default since the firmware was not done in a proper manner may be it had interruptions..once the hard reset is done the computer is restored back to the default so that you can use the device..
Feb 13, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
NetGear RangeMax WPN824 Wireless Router (WPN824NAR) Wireless connection drops in and out regularly but frequency of this is unpredictable duration is usually a few seconds. Works find on direct ethernet...
Upgrade the Firmware of the router :
First you should check the version of you WPN824 (v1,v2 or v3). If there are no Version after the model number, it should be a version 1. Download the Firmware of your router given the correct version at this link :
This is assuming that other wireless laptops has the same problem onyour wireless router. If other Laptops works great on your wirelessrouter without dropping any wireless connection, then you shouldconsider upgrading the wireless adapter on you own laptop.
***(If you haven't tried connecting otherwireless laptop wirelessly to the netgear, then you should try it firstto be sure that the netgear is the problem)
Steps on how to upgrade Netgear firmware :
  1. Download the correct file depending on your location and unzip the file to a convenient place such as your desktop.
  2. Log in the router at or (or ) (Which ever will work)
  3. Default User name : admin / password : password
  4. Click Maintenance > Router Upgrade.
  5. Click Browse and locate the file you just downloaded.
  6. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
***Therouter reboots when the upgrade is complete.
***Tocheck that the upgrade was successful, log in to the router again at check the firmware version.
Oct 26, 2008 | Computers & Internet
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54GL Router Logo
630 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
