Question about Yamaha HTR-5730 Receiver
No output from Yamaha RX-V350/HTR5730
Hi:
I have a Yamaha HTR-5730 receiver that went dead. The protection circuit activated. I replaced one of the STK403-130Y ICs and it comes on again. All the menues work fine also the tuner only nothing comes out, neither at the Phono output nor for the speakers. I tried everything but had no luck. Do you have any idea what the problem could be. I would appreciate any advise.
Thank you,
Horst F. Hippe
Noggin
  • 944 Answers
SOURCE: Yahama HTR-5730
Here's the manual; http://www.yamaha.ca/av/PDFs/Manuals/2004_receivers/HTR5730E.asp See if you find a solution in there - if not please ask again and we will see what we can do :)
Posted on Apr 16, 2007
cancerags
  • 36 Answers
SOURCE: Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
Posted on Jan 01, 2008
SOURCE: yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Posted on Apr 03, 2009
SOURCE: No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Posted on Apr 14, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Posted on Jan 15, 2011
Receiver does not respond to remote, will not turn off or on with the remote what is wrong?
Dear sir my name prakash my won us Yamaha AV Receivers Model RX-V673 Go To died mode what this problem please sir?
Jan 06, 2014 | Yamaha HTR-5730 Receiver
Page 52
Jan 15, 2011 | Yamaha HTR-5730 Receiver
I have att an uverse remote that turns on my Yamaha receiver, but won't control the volume. Model No rx v480
You need to try other codes for Yamaha, as clearly the one you have put in the remote is incorrect, perhaps it was for an earlier model.
Mar 07, 2010 | Yamaha HTR-5730 Receiver
Problem with a subwoofer output..
Check your settings in the Receiver Main Menu. Go to Speaker settings, then to Subwoofer, and select "Yes" or "On" or it may say "LFE or Both" choose "Both" Hope this helps. If you still have a problem, post a comment and I can help you some more
Aug 11, 2009 | Yamaha HTR-5730 Receiver
Htr 5730 is DEAD, no display, will not turn on...
Pull the top off the unit. Look where the AC enters on the inside, check the fuse. It's the only one on the unit. If it's blown replace, if not, the unit needs to go to service. Hope this helps
Jul 07, 2009 | Yamaha HTR-5730 Receiver
Overheated Receiver
No, newer receivers are built to shutdown at a certain temperature point to avoid damage.
I wouldn't be too concerned.
Just make sure and allow more air circulation for the future.
Mar 23, 2009 | Yamaha HTR-5730 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Hello srqwrk,
cancerags
Nov 26, 2007 | Yamaha HTR-5730 Receiver
Yamaha htr5730 receiver - turns off
You may have speaker wires touching each other or a short circuit in the wire. "Check SP Wires" means to check your speaker wires.
Oct 16, 2007 | Yamaha HTR-5730 Receiver
Yahama HTR-5730
Apr 16, 2007 | Yamaha HTR-5730 Receiver
Yamaha HTR-5730 Receiver Logo
330 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
