Question about Garmin Quest GPS Receiver
Garmin Quest frozen
I have a Garmin Quest and as I was changing the units set up it froze. Ican not turn it off.How can I fix this please. I also would like to know if it has a reset button or not. If it does do you know where it is hiding.
thankyou
  • 385 Answers
You Could try pressing the OK button and the PAGE button, together and then hold power button until it reboots and then say yes to erase all user data
This will erase all data stored on the device,
It will need re-registering and re-updating
Here register
Here update
I hope this helps
Regards.
Posted on Apr 16, 2009
Garmin froze with a "Map Update Notice" the screen
The unit isn't frozen. If you tap the power button you will hear it beep and change screens. What has happened is your touchscreen has failed. This is a common problem. Your touchscreen needs replaced. If you want some troubleshooting info, please see this link. There is just too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 20, 2011 | Garmin Nuvi 660 GPS Receiver
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
As I was driving and using my garmin, changing from my route to "detour" and back the screen froze (80 minutes ago). Since I tried to turn off (using power switch) and I also unplugged. Garmin remains in...
Try resetting the unit. Remove the faceplate (there is an indentation at the top) and press the Reset button on the right side of the unit. If this does not help, there is a Master Reset, but it WILL ERASE ALL OF YOUR FAVORITES. If you have to do this, press and hold the bottom right of the screen and press the power button until the unit resets.
My Garmin Nuvi is frozen with a white screen, all I did was take out the memory card and it froze. What can I do?
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
May 14, 2009 | Garmin nuvi 205W GPS Receiver
The garmin is on but frozen
Look near the SN # and press the reset button.
or
Mar 27, 2009 | Garmin zumo 450 GPS Receiver
Garmin nuvi 200 frozen screen
Mar 16, 2009 | Sony NV-U71T GPS Receiver
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
Garmin Quest is out of whack
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Apr 04, 2008 | Garmin Quest GPS Receiver
Rong turns
Hello, I also own a Garmin Quest GPS and I live in Australia, Invariably my quest sends me in the wrong directions, and also in the middle of a highway get a message do a U TURN. I only believe this error resides in the MAPSOURCE Software. and until GARMIN decides to fix the problem there is NO solution for the USER to FIX. I also do NOT believe any more the specification that garnin states with the quest GPS, I believe it can ONLY be bad Telemetry downloaded from the satellites or you have TOO MANY waypoints stored in your GPS. The Solutions I am about to give you are my way of fixing the GPS until the problem reoccures. I suggest you do OPTION 2.
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
OPTION 2 Before you do this DO YOU KNOW HOW to RELOAD your MAPSOURCE MAPS.
Simply turn the Guest on and allow the battery to fully discharge, this is also a good practice to cycle the battery. usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Mar 23, 2008 | Garmin Quest GPS Receiver
No Reception with Garmin Quest
You can find a discription how to reset the GPS here (http://www.elsinga.net/quest-first-aid).
I've already tried it and all the suggested solutions like discharging the battery, changing the date, ... , but it diden't help.
littletramp on worldtrip
Aug 28, 2007 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
451 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
