Question about IBM ThinkPad T42 Notebook
My Sahara laptop's two buttons were broken. One was repaired from Sahara Shop. But other one could not because i have lost a small rubber part of button. Is it available on any shop? If i get it then i think Sahara will repaire it as well and of course free. Please Help!
  • John Sparozich May 11, 2010
    Please explain what these buttons are for, but you should probably have the repair shop fix the problem.
My psp start button does not work
might the rubber contact was broken, you need to open the cover case. just make sure you have the right tools like t6 then be careful not to damaged and lost other small parts.
Sep 06, 2012 | Sony PlayStation Portable (PSP) Console
My computer screen continuously turns black and the only way to get it back to normal is to press the little rubber button near the power button. After it returns to normal, it turns black within 5...
I think the little rubber button must be the one in the lower corner of the plastic face that goes around the screen? If so you have one of several problems.
1. That little rubber button is a screw cover and it conceals a small Phillips head screw that may be loose and shorting the wire that carries the signal to your screen. Gently pry out the little button and carefully tighten the screw.
2. If that doesn't solve your problem, here is the first of the further possibilities. A little panel behind that same screen border of plastic (it called the "bezel") named the "inverter" has a loose plug or is wearing out.
3. The LCD (screen) has a plug attached to the wire that runs by the screw behind the bumper which is loose inside where it plugs into the motherboard.
These problems need to be checked by someone very familiar with taking apart and repairing laptops. But at least now, you know what the problem might be and can talk to a repair guy about it and not get taken advantage of.
Best of Luck!
Sep 05, 2010 | Acer Aspire 5100 Notebook
The on button on my Toshiba laptop is beginning to not work (I'm lucky to be able to get it to turn on.) Can a repair tech replace that button so I don't have to worry that I won't be able to start my...
If your laptop is out of warranty, you should look for a repair service that will charge you only for the replacement of the button (which involves quite a lot of work, to be honest, so it won't be extremely cheap), and not a repair shop that will tell you that they don't care which part is actually broken, and just replace the whole motherboard, which will cost you half the price of the laptop.
If the computer is still under warranty, then you are good, because it's not your problem if the service will replace the button or the whole board inside :)
Good luck :)
Nov 18, 2009 | Toshiba Satellite A100-S8111TD Notebook
My Sahara NB 610 Laptop has no wireless driver
go to the website of the manufacturer of your laptop. more than likely u will find the drivers there for download. if u find them after downloading right clik on the file and click install. if u dont find them there go to drivers.com. this usually works but sometimes hard to find what u want. dont pay for them.
Jul 29, 2009 | Dell Dimension 8300 PC Desktop
I lost My sound Driver of sahara laptop, need a driver Urgently.
Hi...
If your sound card driver of your laptop is lost, don't you worry. There a re many way's to find the driver, the first things you should do is to visit the sahara website, now you in sahara site, so you just type and search the model of your sahara laptop, then after you have search and you can see now the model, you can start to download your sound card driver.
Good luck !!!
Regards
PCmania
Jul 11, 2009 | Dell Dimension 8300 PC Desktop
I have a sahara N1356 laptop which I formatted, lost all drivers
Borrow a friend's laptop and download and copy drivers from the Internet to your Sahara as needed. It may be a long process.
Jun 14, 2009 | Dell Dimension 8300 PC Desktop
I NEED WIRELESS DRIVER FOR MY SAHARA NB 610 LAPTOP
Go to Sahara's website http://www.sahara.co.za/support_center.php type in your product model and download the specific driver. hopw this helps.
Mar 11, 2009 | Dell Dimension 8300 PC Desktop
Sound device
my laptop sound is not working, its a sahara laptop, it keep on showing error messages everytime a try to play a cd
Oct 16, 2007 | Computers & Internet
IBM ThinkPad T42 Notebook Logo
87 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
