Question about Ricoh Aficio GX3050 GelSprinter
Ricoh Aficio GX3050 GelSprinter error 999
I got this err 999 when i try to switch on the printer
  • rickovitz Mar 31, 2009
    printer won't start up. error message 999. i am clueless
3 Suggested Answers
newport74
  • 58 Answers
SOURCE: Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Posted on Feb 27, 2010
SOURCE: Aficio GX3050 GelSprinter: Error 999 appears. When machine starts up, machin...
http://www.katun.com/downloads/catalog/csa-english/Katun-RC-Fax-LA-Jan2010.pdf
http://www.service-manual.net/ashop/catalogue.php?cat=283&exp=0&resultpage=7&shop=1
You must get a service manual to even have a shot at repairing it. This sounds like a motor drive, sensor, problem?
Posted on May 20, 2010
How to refill ricoh gelsprinter gx2500 ink cartridges
I using gelprinter recoh gx 3050, how i can refill this cartage
any branch in India give me gel ink & refillable cartage
pl. give advice abou
sujitgajre@gmail.com
Nov 08, 2011 | Ricoh Aficio GX3050 GelSprinter
Print striping
Sounds like a dirty platen (that cylindrical roller thing). If you can get to it, use isopropyl alcohol on a rag.
Feb 25, 2010 | Ricoh Aficio GX3050 GelSprinter
APPLICABLE MODEL:
SYMPTOM:
CAUSE:
- Low humidity
- Low Print Volume
 COPY QUALITY
Right Flushing Gate
Levers
Page 2 of 5
SOLUTION:
below).
NOTE:
Feb 02, 2010 | Ricoh Aficio GX3050 GelSprinter
I have same problem - if I find a solution I will post it
this is a problem caused by the gel that is not supplied anymore in the printer. certainly the waste ink collector behing the machine is full. by replacing it i solved the problem sometimes, sometimes it is more serious ans the sparepart of the supply must be replaced by crafted man.
hope it can help !
Aug 21, 2009 | Ricoh Aficio GX3050 GelSprinter
RICOH GX3050N and Windows Vista
You can find the driver on the Ricoh site. here is the link:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/gx305/gx305en.htm
Mar 14, 2009 | Ricoh Aficio GX3050 GelSprinter
My ricoh 305on is displaying error 990. I have
change the ink collector located in the rear of the machine
Mar 11, 2009 | Ricoh Aficio GX3050 GelSprinter
Ricoh Aficio GX3050 GelSprinter Logo
1,080 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
