Question about RCA 27V520T 27" TV
No color tv on wall mount - while hooking up device to back of tv, it began to fall forward but was caught in the nick of time and resecured to mounting tray. Problem is, we lost our color when this happened.  Is there something I can do to fix this? I already have unit down, with back panel unscrewed. thank you, jack
    Genius:
  • 1,239 Answers
Hi sir
there are only two problems in the case you said
check the colour wheel and cathode ray tube ....
Posted on Mar 07, 2009
How thick are the walls in my forest river wolf pack? I want to mount a tv to the wall.
make a wooden support at the mounting bracket before you mount it to the wall this will support your tv from accidental falling
Dec 02, 2016 | Televison & Video
Mounting tv on wall
You would need to get a flat panel wall mount. Since you are unsure on how to do this, I would strongly recommend hiring a professional or handy man with experience installing the mounts. Not installing the wall mount properly could cause the TV to fall and damage the set(warranty will not cover the damage) or cause bodily harm to somewhere.
Sep 03, 2012 | Scott LCT37SHA TV
Sink falling off wall
Well first step would be to remove sink from wall.then determine if there is backing in wall (something study behind wall to anchor bracket to) Most of the time when its falling off the wall its due to improper backing or non at all, bracket mount screw rusting away.I seen sheetrock screws holding them on. (that would last long) I suggest 3/8x 2" lag screws.
Feb 03, 2012 | American Standard 0194 - Roxalyn...
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
Is there a specific wall mount for this TV to swival in all directions
Acquiring wall mounts for television are according to preferences. For example, wall mounts that provide the TV dynamic directions to suit operators requirements would have separe requirements. The multidirectional wall mount provides the TV capability to swirl around several angles. Howeever, acquiring wall mounts as requirement to encamp the TV also placement on safe areas from which the device is observable is an alternative considerations. TV wall mounts provide multi purpose functionalities. For example, TV wall mounts that provide both encampment housing placement hinging to an area, and finallly capable of multidirectional functionalities available for acquisition at retails. Also possible are acquisition of customisable wall mounts to suit the type of placement area required on TV sets either suitable at various locations. For example, TV wall mounts are customsiable to house sets that require functionalities with complimentary devices like decoders, modems, DVD players, VCR recorders, or cable wiring. The process of acquiirng wall mounts is achieving interhrety of the TV set, housing available devices requiredm and achievifn viewer egonormics. Consult room device area estimate expert before acquirng wall mount to ascertain the appropiate conditions capable of providing egonomic experiences. Goodluck
Jan 08, 2011 | Televison & Video
Can I use any universal wall mount for my LG
Just check the weight and size restriction on the wall mount. As long as the weight and size specs of the TV fall within those allotted by the wall mount, you should be fine.
Nov 13, 2009 | LG 50PC5DC 50 in. Plasma HDTV
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
Want to wall mount tv but don't don't were to bolt.
I have my 32" Protron mounted on my wall. There are six holes on the back of the set that you attach the mount. I cant find any links to pictures but it should be pretty straight forward. You should be able to use any generic LCD wall mount, just make sure it can hold an 32" since I made the mistake thinking all wall mounts were the same. I purchased mine at Best Buy but you should be able to find a mount anywhere. You will need to fasten the mount onto the studs in your wall. Drywall by itself will not be sufficient and cannot support the weight of the TV.
The wall mount should come with everything you need, e.g., screws, brackets, etc., with the exception of the tools. FYI... it's not going to be an easy job so be patient and take your time. It's probably going to take the good portion of a day. Also, as for the holes on the back, just be careful when performing the final mount to make sure it doesn't fall. It would be wise to have someone help you.
Nov 25, 2008 | Protron PLTV-32 Television
Stand
You would need an actual wall mount bracket for your TV. Here is a link that you should be able to find what your looking for.
http://www.mountsandmore.com/TV-Mounts-C135.html?refid=OV81.tv+wall+mount
Mar 12, 2008 | Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
