Question about Canon MP610 Photo All-In-One Printer
MP610 Black Ink Not Printing Properly
The printer advised that the black ink had run out. It is the larger cartridge (2nd from the left).
It was replaced but the first 5 prints resulted in the black ink being applied as if the ink had run out. It looks like streaky lines.
I initially thought it was the ink cartridge as the machine has never had a problem. I changed the cartridge but it suffered the same problem.
Any ideas? Many thanks in advance.
  • 2 more comments
  • js Mar 07, 2009
    Have run the cleaning program a 2nd time and the problem has cleared up.
  • js Mar 07, 2009
    The cleaning program has been used, I selected the "mostly B" option and it detected the nozzle was clogged.
    Printer is now working 100%.
    Thanks for the help :)
  • js Mar 07, 2009
    Well, after the solution the problem had returned.
    It begins to print the document, a black image, and 50% through it continues to print black using incomplete lines.
    Can't see what else can be done apart from taking it in for repair. Machine is only 2 months old.
    Any ideas?
  • Thomas F. Schneider May 11, 2010
    Have you used the head cleaning program as outlined in the instruction manual?
    President:
  • 2,692 Answers
Fix Ya?
Posted on Mar 07, 2009
Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Feb 05, 2010 | Canon PIXMA MP610 InkJet Printer
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
I have run out of black ink in the large cartridge. Can I make the rpinter use the smaller cartridge to print black and white?
No, the larger cartridge is used for text printing only.
The smaller cartridge is used to add black to images instead of using the color ink to make a composite black.
Don
Oct 23, 2009 | Canon MP610 Photo All-In-One Printer
I have a Pixma iP4500 printer.When I buy ink, the #5 black ink tank isn't included in the box. There are 2 black ink tanks in the printer.The #8 black ink tank hasn't been used and the #5 is out(as are the...
There are two black inks in the printer so that when you are printing only black and white such as printing a fax or when you set print in B/W for printed matter, the printer will use the larger ink cartridge. When you are printing in the multicolor mode (most people don't know the difference) the printer will use the finer black ink in the smaller cartridge. This smaller cartridge is used for photo printing and multi-color page printing. You cannot mix the two blacks since the larger cartridge is a coarser ink.
Jun 06, 2009 | Canon Pixma iP4500 InkJet Printer
Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
May 30, 2009 | Canon MP610 Photo All-In-One Printer
Ink cartridge running low will it default small cartridge
It won't default to the small one...I emailed Canon support; this is the response I got.
The reason for the two different black ink tanks is for the different types of printing your unit is capable of. They are not intended as backups to each other. The larger black tank is pigment based, and is primarily used for standard black text printing or output. The smaller black ink tank is dye based like the color inks, and is used for photo and graphics output. They are designed to complement each other, allowing the printer to produce the best possible black text output or photo quality as appropriate.
Feb 25, 2009 | Canon PIXMA MP610 InkJet Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Cartridge problem
Basically, you placed a black ink cartridge [30] into the compartment for the color one [31]?
Make sure you have a black ink cartridge in the left compartment, and a color one in the right one. I don't even think it would properly fit if they were in the wrong slots. They should "click" into place, confirming that they're installed properly.
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Does not recognise the smaller black ink cartridge
This machine is not meant to switch between the two black cartridges. The large one is used when you are using black only, and the small one is used when you are printing in color.
Jul 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP610 Photo All-In-One Printer Logo
810 people viewed this question
old marine
old marine
