Paul,
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/Download> Select OS (I just clicked on WinXP) > Click on the + sign next to Manual (5)
Version 1877
P4VP-MX user's manual English version E18772.5 MBytes
Click on the blue -> Global
Or copy this,
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4vp-mx/e1877_p4vp-mx.pdf
Paste it in your address bar, and press the Enter key.
(May take up to 30 seconds before the first page comes up)
Page 17 - Motherboard Layout
(PDF file page. 1-7 for the actual manual page)
Page 28 - Front Panel Audio Connector (1-18)
Page 30 - USB Header (10-1 pin USB56) (1-20)
Page 32 - System panel connector (10-1 pin PANEL1) (1-22)
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main cables, (Wires), go to, is the Front Panel header.
Motherboard as installed in computer case;
Processor to the top, Ram Memory slots to the right, white PCI slots to the bottom;
The Front Panel header is located at the Bottom/Right corner.
PANEL1.
Two rows of pins.
(To the left of it is the front panel USB header. USB56. Looks very similar)
Doesn't show numbering for the pins. (Contact pins)
I'm going to number them for easier orientation
The pins across the TOP are numbered ODD.
Starting on the LEFT side going towards the Right;
Pins 1, 3, 5, and 7. There is NO Pin 9.
The pins across the BOTTOM are numbered EVEN.
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the LED is dim when the computer is on, switch the wires around.
B) Pins 5 and 7 are for the Power On switch.
C) Pins 2 and 4 are for the HarDDrive activity LED (Light)
May be marked on the wires as HDD, or IDE.
Pin 2 is for the Positive ( + ) wire.
If the harddrive activity LED is dim when the harddrive is active, switch the wires around.
D) Pins 6 and 8 are for a Reset switch, IF a Reset switch is used.
E) Pin 10 is N/C
Not Connected. (Probably a +5 Volt point for the factory to use)
Have problems downloading, or saving the PDF manual, post back in a Comment.
For additional questions post back in a Comment.
Regards,
joecoolvette
[Motherboard chipset;
Northbridge -> VIA VT8751A (Also known as VIA P4M266A)
Southbridge -> VIA VT8235
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Socket_478http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg[CPU = Central Processing Unit. Another term used is Microprocessor, or simply -> Processor, for short ]
