Question about Lenovo 3000 Y410 Notebook
1. My ideapad Y430 easy cam doesnot working after i reinstall windows vista ultimate. Not i cant use it for my password. 2. I also try to partition it into four but it doesnot support i can have only two partition. 3. i cant install Windows XP3 in this machin. plese halp me.
  • 170 Answers
This is all I can offer in your situation.....one option is to..use the...
Novo button
This button functions as a reset button; use with caution. Press the
1. Novo button to enter the main interface of OneKey Recovery while the
power is off. You can use OneKey Recovery to restore the primary
hard disk partition (usually drive C) back to the factory default
configuration, including the operating system and the software on it.
Attention: Once done, the system can no longer return to its previous
state. All data on the primary hard disk partition (usually
drive C) will subsequently be lost. So make sure all
important files on the primary hard disk partition have
been backed up onto another hard disk or USB hard disk
drive before this operation.
For details, see “OneKey Recovery4.65 User Guide
2. For the camera check out these key functions....
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
3. And for the password...here you go....
Using Passwords
Using passwords helps prevent your computer from being used by others.
Once you set a password and enable it, a prompt appears on the screen each time you power on the computer. Enter your password at the prompt. You cannot use the computer unless you type the correct password.
Make sure that only authorized individuals access your computer.
Establishing different kinds of passwords requires that other possible users know the proper passwords in order to access your computer or your data.
As many as three passwords might be needed for your computer: the Supervisor password, the User Password, and the hard-disk drive (HDD) password. When the Supervisor password is set, only the Supervisor password entitles you full control of the computer.
• User password
If a user password is set and Password on boot is enabled, a password prompt appears when you turn on the computer. Unauthorized users cannot get access to configuration data.
You can also use the user password to enter the BIOS Setup Utility, but once the Supervisor password is set only a part of the options can be set.
• Supervisor password
With a Supervisor password, you can get full control of the computer. It also can be used as a power-on password, the same as the User password. Also, when you enter the BIOS Setup Utility with a Supervisor password, you are entitled to set all of the options.
• Hard disk (HDD) passwords
Once an HDD password is set, you need to enter it to get access to the hard disk. You can set the HDD password through either the User Only selection or the User + Master selection in the BIOS Setup Utility.
Note: If you set passwords through the BIOS Setup Utility and you put your computer into sleep mode by pressing Fn + F1, the following describes the behavior of the computer when you bring it out of sleep mode:
• You are prompted to type the Windows log-on password rather
than the User password to resume operation.
• If an HDD password is assigned to any hard disk drive, the hard
disk drive is unlocked automatically when you resume operation.
To set a User Password:
1. Turn on your computer. Press F2, while the initial screen is displayed.
The BIOS Setup Utility screen opens.
2. Select Security, using the cursor directional keys.
3. Select Set User Password, and press the Enter key. The Set User Password window opens.
4. Choose your user password, which can be from one to eight
alphanumeric characters in any combination. Type it in the Enter New Password field.
5. Press the Enter key once to move to the Confirm New Password field. Retype the password you just entered to verify it.
6. Commit your password to memory, and press the Enter key.
7. Press F10 to exit.
8. Select Yes in the Setup Confirmation window.
Changing or Removing the User Password
To change the password, do the following:
1. In the Enter Current Password field, type your current password.
2. In the Enter New Password field, type a new password; then retype it to verify.
To remove the password, do the following:
2. Leave the Enter New Password field blank, and then press the Enter key twice.
Note: Make sure the Password on boot is set to Enabled if you need the password protection at power on.
To set a Supervisor Password:
Only a system administrator will be able to perform this procedure.
2. Select Security using the cursor directional keys.
3. Select Set Supervisor Password, and press the Enter key. The Set Supervisor Password window opens.
4. Choose your supervisor password; it can be from one to eight
5. Press the Enter key to move to the Confirm New Password field.
Attention: You might want to note your password and keep it in a
safe place. If you forget your supervisor password,
Lenovo can not reset your password. You must take your
computer to a Lenovo reseller or a Lenovo marketing
representative to solve this problem. Proof of purchase is
required, and a fee will be charged for parts and service.
The next time you open the BIOS Setup Utility program, you will be prompted to type your password to proceed.
Changing or Removing the Supervisor Password
1. In the Enter Current Password field, type the current supervisor
password.
2. In the Enter New Password field, type the new supervisor password; then retype it to verify.
password.
Hard Disk Passwords
Two types of the hard disk passwords help protect the information stored on the hard disk:
• Hard disk user password
• Hard disk master password, which requires a hard disk user password If User only is selected and a hard disk user password has been set, but no hard disk master password has been set, the user must enter the hard disk user password in order to gain access to files and applications on the hard disk.
If User + Master is selected you need to set a master password and a user password both as the Hard Disk Password. Either of the two passwords can be used to get access to the Hard disk. Any change or removal to the master password deletes the user password.
To set a hard disk password:
Print these instructions.
3. Select Built-in HDD1 Password Select, and press the Enter key. A window for selecting User Only or User + Master opens.
I will send the rest in the comment section..hope this helps in some way...the Fang.
Posted on Mar 26, 2009
  • Leslie Looman
    Leslie Looman Mar 26, 2009
    Here is the rest of the password info langpok.
    4. Select User Only if you want to set only one HDD password. If you are an administrator or supervisor, you can select User + Master to set two passwords. (The administrator can change the user password later.)
    5. If you select User + Master, go to step 9.
    6. If you select User Only, select Set HDD User Password, and press the Enter key. The Set HDD User Password window opens.
    7. Choose an HDD user password, which can be from one to eight
    8. Press the Enter key once to move to the Confirm New Password field.
    Retype the password you just entered to verify it. Go to step 16 to
    complete the procedure.
    9. If you select User + Master, select Set HDD Master Password, and press the Enter key. The Set HDD Master Password window opens.
    10. Choose an HDD master password, which can be from one to eight alphanumeric characters in any combination. Type it in the Enter New Password field.
    11. Press the Enter key once to move to the Confirm New Password field.
    Retype the password you just entered, to verify it.
    12. Commit any password to memory, and press the Enter key.
    13. Select Set HDD User Password, and press the Enter key. The Set HDD User Password window opens.
    14. Choose an HDD user password, which can be from one to eight alphanumeric characters in any combination. Type it in the Enter New Password field.
    15. Press the Enter key once to move to the Confirm New Password field.
    16. Commit any password to memory, and press the Enter key.
    17. Press F10 to exit.
    18. Select Yes in the Setup Confirmation window.
    The next time you turn on your computer, you will have to type the HDD user or master password in order to start your computer and get access to your operating system.
    Changing or Removing the HDD Passwords
    To change or remove the User Only HDD password, select Set HDD User Password and do as follows:
    • To change the HDD user password, type the current password in the Enter Current Password field. Then type the new password in the Enter New Password field, and retype it to verify it in the Confirm New Password field.
    • To remove the HDD user password, type the current password in the
    Enter Current Password field. Then leave the Enter New Password field
    blank, and press the Enter key twice.
    To change or remove the User + Master HDD password, do as follows:
    • To change the HDD user password, select Set HDD User Password and
    type the current HDD user password in the Enter Current Password
    • To remove the HDD user password, select Set HDD Master Password and type the current HDD master password in the Enter Current Password field. Then leave the Enter New Password field blank, and press the Enter key twice. Both HDD user and master passwords will be removed.
    • To change the HDD master password, select Set HDD Master Password and type the current HDD master password in the Enter Current Password field. Then type the new password in the Enter New Password field, and retype it to verify it in the Confirm New Password field.
    Note: When you change the HDD master password, the HDD user
    password will be removed.
    • To remove the HDD master password, select Set HDD Master Password and type the current HDD master password in the Enter Current Password field. Then leave the Enter New Password field blank, and press the Enter key twice. Both HDD user and master passwords will be removed.
Extenter speaker are not working
Reinstall the driver
plug headphones and play a video or music file
if you hear it ok then the driver is installed ok
Laptops and netbooks IdeaPad Series laptops IdeaPad Y430 Lenovo Support...
check your settings
  1. Click Start and type "sound" into the search bar. A list of search matches is displayed.
  2. In the search results, click Sound under the Control Panel list.
The Sound screen is displayed.
Jul 13, 2014 | Lenovo IdeaPad Y430-3231U Notebook
I forget my window password. how do i remove it
No need to reformat your laptop, it will lose your important data.You can recover the lost windows password.
When youforgot windows xp password, read Crack Windows XP LoginPasswordAnd forgotwindows 7 or windows vista password, readBreak Windows PasswordOthers, read How to Reset Windows Password
Jun 09, 2012 | Lenovo Ideapad Y430 (5.90188E7) PC...
For the past few days my Lenovo IdeaPad Y430 has been booting up as usual up to the point where i put in my username and password. I get a black screen with the cursor after i log on and cannot go beyond...
Hi verneaimable,
I'm glad to help you out with the boot up issue of your Ideapad Y430. Based on the details that you have provided this is leading to a software issue. To address this concern, you need to reload the Operating System of your machine. OS has been corrupted causing you not to boot up on Windows. Lenovo do have this One Key Recovery button that you can use. You need not to worry because I have step by step procedure below making it easy for you to do the process:
Discalaimer: Using the One Key Recovery will put back your machine to it's factory settings. Any important file/software you currently have will be wiped out. You might want to create back up copy first of all your files before continuing on the process.
Steps:
1. Turn off your compter.
2. Look for theOne Key Recovery button on your PC. It's near the power button.
3. Press the OKR button, wait until your computer turns on.
4. After Windows loading files you'll be routed on Lenovo One Key Rescue System.
5. Select One Key Recovery then, select restore from Intial back up.
Usually it will take 20-30 minutes for the whole process to be done. Once it's finish just reboot your computer. You'll now have the operating system reloaded to your pc. This should fix the issue.
Hope it helps.
Thank you for using Fixya.
Nov 06, 2010 | Lenovo IdeaPad Y430-3231U Notebook
Camera not working
go to my computer,open the drive that you used to install on, i'm asuming C then go to program files, look for your camera folder,delete it, that deletes it completly, if you have any drive cleaner's ,,run them, couldent hurt!!,,now try to reinstall. if nothing still, maybe a systym restore when the cam worked, good luck
Dec 20, 2009 | Lenovo IdeaPad Y430-3231U Notebook
Cannot turn on my cam in lenovo y430
Uninstall and re-install the driver
and download the easy camera software for your webcam at
consumersupport.lenovo.com
Dec 17, 2009 | Lenovo IdeaPad Y510 Notebook
How does the built-in camera of ideapad y430 with vista work??
This is the technical support telephone for the Lenovo Notebooks in the USA. You can call them for any troubleshooting problems. I am sure they will be able to help you get the operation of you web camera back to normal. Thank you for using FixYa and have a nice day!
United States
English
1-877-4Lenovo (1-877-453-6686)
Notebook
24 hours a day 7 days a week
IdeaPad & Netbook
Jun 07, 2009 | Lenovo 3000 Y410 Notebook
I recently purchased lenevo ideapad laptop. in that total hdd space is divided into 2 drives .if i want 2 divide into more drives ,wht can i have 2 do? i have vista os.
you can create additional drive partitions by right clicking on my computer, select manage, and open the computer management snapin console, once there you should go storage-disk management, select the drive you wish to partition from there
Mar 24, 2009 | Microsoft Windows Vista Ultimate Edition
Acer orbi cam
you can restore applications and drivers from the restore discs or partition.
Mar 25, 2008 | Acer Aspire 5610 Notebook
Lenovo 3000 Y410 Notebook Logo
1,285 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
