Question about York Yankees Bedding MLB Comforter
Need a User Manual for a York (p2mpd16n09601)
Need a User Manual for a York (p2mpd16n09601f) furnace.
How can I find a user manual for a York Pacer 2500 to print please ?
go google and type in--- user manual for york pacer 2500--and if there are pdf versions for download , that is where it will be
Oct 22, 2016 | York Exercise & Fitness
York furnace trippin roll out switches
Is your filter plugged? If so, change it out. is the bottom door on the furnace? Is the draft motor running at normal speed?
Jan 05, 2013 | York Furnace Draft Inducer Blower Fasco #...
I have a York Gas Furnace that is 6 months old. The furnace will run for 5 hours like it should and then shuts down. I get 6 red light flashes. According to the manual the presure switch is bad. I...
These pressure switches are safety features on ALL new furnaces, if replacing the switch didn't solve the problem, you might want to make sure there is no blockage in the exhuast pipe like a birds nest, anything that would restrict airflow, is there inline fan motor in the exhaust pipe ? perhaps it's not working also.
Jan 23, 2011 | York Furnace Draft Inducer Blower Fasco #...
York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Where is the furnace filter located on the York P3CGD12N08001B
Residential furnaces have exterior filter boots supplied by installer, commercial york units have filter access doors. If this is a roof top unit your filters would be in the door to the left of the blower compartment.
Nov 18, 2009 | York Yankees Bedding MLB Comforter
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
INSTALLATION MANUAL FOR PV9C YORK FURNACE
I just replaced a thermostat on a york furnace model gy9s100c16up11h. During the process i connected the red and white wire and the unit came on after making the connections it will not come on even if I jump the red and white wires without the thermostat. Thanks Dan
Jun 10, 2009 | Heating & Cooling
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Owners Manual
York Corporate Headquarters
631 South Richland Ave.
York, PA 17403
Phone: (717) 771-7890
Contacting York
Mail:
York International Corp.
P.O. Box 1592
York, PA 17405-1592
USA
Phone: (877) 874-7378
York Website
York was purchased by Johnson Controls in 2005
Johnson Website.
I cannot find an actual manual online. I hope this information helps you. Good Luck.
Dec 27, 2008 | York Yankees Bedding MLB Comforter
York Yankees Bedding MLB Comforter Logo
223 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Shehu Pro
Shehu Pro
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
