Question about RCA HDLP50W151 50" Rear Projection HDTV
I have RCA HD50LPW167 DLP TV with NO Sound and NO Audio. The LED blinks when I turn the TV on but that's all it does. Took it to the local RCA authorized repair shop and they told me that the digiital module needs to be replaced for $780.00 which is not worth to repair. I'm not convinced that the whole DM board needs to be replaced and the cost of it. Anyone knows where to get the replacement for the DM myself? Or is there known problems with this unit that I should be looking for any specific component? Thanks for your help. Please reply to elginrs@msn.com Thanks.
  • gloomwriter Mar 09, 2009
    rca 50 inch dlp model # m50wh72sysyx12 or g253606y when powered on green light is steady flashes 4X then steady and powers off no audio and does not make any sound.  I was previously told replace bulb and I did but changed nothing.
  • 201 Answers
Still sounds like a lamp:
TV won’t turn on
• Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
• Make sure the TV is plugged in.
• You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
• Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or fl ashing
section below for more information.
• When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
on after the Power indicator goes off.
• Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 84.
Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
Remote Setup. Choose TV (default).
Power indicator is blinking or fl ashing
If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
then the light blinks steadily for one minute, one of the following options is possible:
• Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
back on. The lamp should turn on.
You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
• If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
the TV. The sticker is located on the right side of the TV.
Hope this helps :)
Posted on Mar 09, 2009
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Mar 04, 2012 | Sharp Audio Players & Recorders
RCA HD50LPW42 dlp, does not turn on
If capacitors are swollen,vented or puffed up on top replace them .You may just need to replace your Lamp.CK all fans make sure they are running. Mats Electronics has Best Price for Lamps 1-800-628-1118
Let me know if you need more help.
Mar 23, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
My RCA TV has no sound. Can anything be done?
"Yes" I recommend calling the store where you purchased it, or a local TV repair man.
Mar 12, 2009 | RCA HD50LPW167 50" HDTV
I need help with my rca tv
probably bad color wheel. not an easy repair. some of the rca dlp required the light engine be
pulled out to replace color wheel.
Feb 24, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
I have an RCA Scenium HDTV DLP, Model HDLP50W151. Turned it on and went through it cycle, whining sound but the screen was gray. turned it off and then on again...no picture and there was no whining sound....
Sounds like the Color wheel on the Light engine has failed. Its a major repair. Contact Thomson at 1-866-465-7157 to find a local authorized repair center.
Jun 04, 2008 | RCA Televison & Video
Rca m50wh74s HELP
Sounds like a bad high voltage transformer (FBT). Call a service center.
Jan 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
600 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
