Question about Sony (UWP-S1) Professional Microphone
We have need for 10 of the wireless transmitter "belt clip" .
We cannot find the wireless transmitter "belt clip" like shown in the attached drawing via the link:
http://www.fixya.com/support/p490815-sony_uwp_s1_professional_microphone/manual-19902/page-5
Does anyone sell them??? HELP!
  • 4,234 Answers
These parts are available directly from Shure. They are not expensive. I don't have the part number with me, but a call to Shure service should get you both the number and cost.
Dan
Posted on Mar 10, 2009
When you compose a new message, click on the "paper clip" symbol at the bottom of the message, as shown in the picture. This will lead you to browse your computer for the attachment. wait patiently for the upload ( upload speed is only 10% of download speed).
May 07, 2013 | Google Gmail
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
Do i need a keyboard and a receiver for the mouse to work and if not how do i hook it up
Your wireless mouse and Keyboard work with the same wireless transmitter that is plug in into a USB port.of your computer. You can use the wireless mouse with that USB transmitter and dont use the wireless Keyboard. If you need a keyboard you can get one to be plug in into a USB port with the wire attach to the keyboard.
Mar 23, 2012 | Micro Innovations KB982W-F Wireless...
I need to find out how to reset the Toyota central locking on my 1994 Celica. Toyota want to charge me $40. every time I get a flat battery. I would appreciate some help, thank you. Toyota Celica central...
Hi Georgia, try this
Before commencing, ensure all existing wireless door lock transmitters are
functioning correctly.
1. Locate the wireless door lock ECU. It is behind the centre
instrument panel.
2. Disconnect and remove the wireless door lock ECU from the vehicle.
3. Remove the four screws from the bottom of the wireless door lock
ECU, rotate and remove the top cover.
4. Remove the four screws from the bottom of the wireless door
lock transmitter and separate the top and bottom covers.
5. Remove the battery and note position for reassembly.
6. Locate the code ROM within the wireless door lock
transmitter.
7. Remove the code ROM from the wireless door lock transmitter
by carefully sliding back the retainer clip on the ROM socket.
8. Then slide the code ROM out of the ROM socket.
9. Locate the code ROM socket provided on the wireless door
lock ECU circuit board.
10. Slide back the retainer clip of the ROM socket.
11. Carefully insert the code ROM into the unclipped ROM socket,
ensuring the contacts are facing towards the circuit board.
12. Slide the retainer clip of the ROM socket forward to lock
the code ROM into position.
13. With the wireless door lock ECU top cover still removed, reconnect
the ECU to the wire harness taking extreme care not to allow any of the
internal circuitry or components to short out on any part of the vehicle.
14. Once in position, locate the reset button on the wireless
door lock ECU circuit board and press once only.
15. At the same time, confirm ROM coding was established by
observing the extension LED. This LED will flash once to acknowledge that
ROM coding was successful.
16. Carefully disconnect the wire harness from the wireless door lock
ECU and remove from the vehicle.
17. Remove the code ROM from the wireless door lock ECU and
refit into the wireless door lock transmitter's ROM socket.
18. Ensure the code ROM is secured and retained in the wireless
19. Assemble the wireless door lock ECU and install into the
vehicle.
20. Assemble the wireless door lock transmitter. Ensure the battery is
installed with the correct polarity.
21. Check security system operation with all wireless door lock
transmitters.
Good luck
Mishy 1
Nov 04, 2011 | 1994 Toyota Celica
I am trying to find where i can buy some belt pack clips for AKG WMS450 bodypack transmitter.
I've had to order them from AKG - you might check Guitar Center and or Musicians Friend online
Mar 28, 2011 | Audio Players & Recorders
How do I order a mic clip for the wireless mic. The one I have broke.
Contact Bosch/EV (formerly Telex) via website or call them. They're in Burnsville Minnesota and their customer service is excellent.
Feb 25, 2011 | Telex WT-55 Belt Pack Transmitter (027)...
Hi The pictures in manual docent show the direction clear . The magnet and the trnsmiter.
magnet gets screwed or clipped onto the spoke.the transmitter attaches to the fork.make sure the magnet on the spoke passes the centre of the transmitter (should be a mark on the transmitter)and also make sure the magnet passes the transmitter with 3 to 4 mm gap.you may have to turn the transmitter alittle to get it closer to the magnet.hope this helps
Oct 14, 2010 | Sigma Sport BC1106 Dts Wireless Bike...
The infra red receiver and detector on my model 65XWX20B projection tv is working intermittently and I think it needs replacement.
Bad batteries and/or clips making poor contact are suspect. The actual detector and transmitter are pretty reliable.
Another possibility is an inteerfering signal such as wireless infared headphones which the transmitter emits continuously. Also a wireless mouse/keyboard could interfere with the signals and effectively block the control from your remote.
Jan 09, 2010 | Hitachi Televison & Video
D60 not firing Paul Buff flashes by cord or wireless set up...
Here is the main support number.You can call them up and find a closest repair center in your location.
1 800 828-4040
If you are in USA you can find a service center from HERE
Goodluck..
Feb 29, 2008 | Canon PowerShot EOS D60 Digital Camera
Sony (UWP-S1) Professional Microphone Logo
323 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
