Question about Cameras
I take pictures inside a car of people and sometimes the pic come in good and sometime not what is the best setting iso
  • 423 Answers
Hi there, and thanks for coming to FixYa.
The ISO setting determines how sensitive your camera's image sensor is to light.
General rule of thumb...the lighter your surroundings are - the lower your ISO. So, depending on how bright the light is outside your car when you take the picture, use this:
If it's overcast 600 to 800 ISO.
If it's really sunny then us 200 to 400 ISO
If it's dark out then only use 1600 ISO
You should experiment with these ISO settings, you may have to notch it up or down depending on the light outside.
Rob
Posted on Mar 07, 2009
I purchased olympus E620. What is the best setting for setting in low lights, for indoors. I tried adjusing ISO, but the pics appear grainy. Whein it's in auto, pics are too dark. When I use the art...
In general, you will have to play with the functions as each camera and indoor lighting situation is different. Sometimes, cameras have some nice presets (like candlelight) and I have had some success with presets.
Otherwise, depending on the indoor circumstances you will need to play with ISO - 800 or 1600 is typical for low light settings. However, I have heard that graininess appears with your camera at around 1600. It is a problem with your model of camera.
You can also try playing with the white balance settings as well.
Jul 26, 2011 | Cameras
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
Dark semi circle shadow and pics too bright
Are you using a lens hood? Is your ISO set too high?
Apr 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
Built-in flash not flashing as expected
I'm not sure if the problem is the flash or settings on your EOS, from what your saying.
Lets try to change the settings first.
Try to change the settings of your camera, look in your manual. What your looking for is ISO, this is the exposure. By taking practice shots and changing ISO you will find a setting that will match your preference.
Also, it seems like your flash is faulty. Contact Canon to fix it for you.
If you have the money, try to fix your flash. Otherwise set your ISO to auto or change it every time you take a picture outside or inside.
Sep 13, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Pics out of focus
Sounds like "Camera Shake"
With Digital photography, any motion of the camera will tend to blur the photos. You'll see double edges in some photos, and plain fussy pictures in others.
The sharpest photos come from cameras sitting on stationary objects while the picture is taken.
Depending on how advanced your camera is, there are a couple of settings you can toy with.
One is the ISO setting which mimics the "Film Speed" exposure rating of camera film measured in as ISO100, ISO 200, ISO 300, ISO 400.
The Ratings are a balance between Fast action light capture, and slow higher resolution detail light capture.
ISO100 will make a cyclist passing by look like they're standing still.
ISO400 will make a cyclist passing by look like a blur passing by.
ISO100 will have larger dots of colors on the picture, (Low Resolution)
ISO400 will have tiny dots of colors on the picture, (High Resolution)
So, ISO setting is a matter of getting the best picture without the blur; get as close to ISO 100 as you can.
The other setting is Shutter Speed.
Some cameras will allow you to slow the shutter speed down to help get clearer pictures in dark environments, like places with high ceiling lights, or outside after sunset.
Again you want the fastest option available, here the balance is the same as the ISO, bright clear picture versus dark blurry picture, so you want the shortest shutter speed possible.
This is measured in fractions of a second, and often only the denominator (lower half) is mentioned, like this:
1/8 of a second is called 8 or (125 milisecond)
1/4 of a second is called 4 or (250 miliseconds)
1/2 of a second is called 2 or (500 miliseconds)
1 whole second is called 1 or (1 for one second)
On digital cameras it often simply mentioned as the fraction in a menu called shutter speed. The default is often the fastest capable speed.
Browse the menu options for ISO and Shutter speed to see what modifications you can make.
Remember it's about capturing the light, so bright sunny days are easy highest speed settings, but shady or indoor environments will take practice and fine tuning.
Also, make use of the timer delay option and set the camera on a stationary object to capture the clearest sharpest images.
Have Fun.
Jul 28, 2009 | Casio Cameras
When using CDBurnerXp burning DVD video's from ISO files, the resulting DVD often does not play properly on a DVD player. Sometimes the sound breaks up, sometimes the picture pixelizes like interference,...
I haven't used that particular program, but I've made hundreds of DVDs. The first rule is to use good brand name media, I recommend Verbatim. Pixelation is a sign of poor quality media quality.
Give it a try with Verbatim disks.
Mar 20, 2009 | Computers & Internet
Grainy pics
When using sport mode the ISO jumps to 400 or more, and this is very noticeable in the grain of the picture. S3 renders good detail up to ISO 200. My advice: Set ISO to 200 in Tv mode, then set the shutter speed to 400 or something like that using the < > buttons. You have to try the best speed under the light you are. If the light is very good, perhaps you can use ISO 100 and get much better results.
Oct 23, 2008 | Canon PowerShot S3 IS Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Good book for a beginner?
have you set it to macro mode? (little flower icon on the right cursor) this function will allow you to get within about 2cm of the subject, however do not use the zoom as the lens cannot focus close enough. To get results any closer you will be looking at an slr and a budget on a few thousand! If enabling macro and not using zoom to allow the lens to focus doesn't get you close enough in you can always enlarge and crop images. have a look on www.picture-skew.blogspot.com i've taken some macros of flowers and bugs, this camera can capture the hairs on an ants back or the individual lenses of a flys compound lens eye.
persevere with this camera, for a very small budget you will get amazing results, ISO refers to the speed of 'film', it comes from the dark old ages of 35mm film cameras. Basically a low ISO is the lowest sensitivity to light and gives the best image quality, however as the ccd is less responsive to the light the camera holds the shutter open for longer. The higher the ISO the more sensitive the ccd but the greater the noise and lower the quality of picture.
Books, try looking for more photography orientated books and less digital camera based books. An upto date photography book will tell you all the technical information about how to take a good picture for any given senario.
if you would like any further advice email me (address on the blogspot)
Dec 20, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Crappy pictures
Describe wierd - this word means nothing. White flash images are over exposed- so reduce the ISO setting to a lowers number if the camera allows it. or Reduce power of the flash. The easiest way to do this is to put layers of tissue of the light reducing the intensity until you get it about right.
Jun 29, 2007 | Polaroid a300 Digital Camera
Cameras Logo
69 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
