Question about Microsoft Computers & Internet
I want know how many hours between two days and time for the purpose of down time calculation
24 hour
in two days
Posted on Mar 07, 2009
Simple pro rata formula for time and money. ie. 1hour = $35 so how long for $23? cant get my head around 1 hour being 60 mins
I suggest you adopt the decimal clock. 0.1 hour (6 minutes) will be $3.50 or 0.05 hour (3 minutes) will be $1.75 and once you have a policy of using those decimal units, time and therefore the cash amounts will be rounded up to the nearest 0.05 or 0.1 hour.
To answer your question use a calculator and divide the required amount by $35 to obtain a decimal fraction of an hour, in this case $23 will buy 0.657 hour which for practical purposes is an unwieldy figure and for most purposes be rounded up to 0.7 hour (42 minutes).
If greater accuracy is required 0.657 x 60 (minutes) = 39.06.
Lots of workshop environments use the decimal clock and vehicle standard repair times and the resulting charges are decimal, the majority to 0.1 but some to 0.05.
I hope this is helpful...
Jan 21, 2017 | Pro Computers & Internet
How many seconds are in a century?
3,153,600,000 seconds in a century.
Jun 07, 2015 | Miscellaneous
How to calculate frequency
Divide whatever it is you're measuring by the time. If something happens once an hour then it's frequency is once per hour, or equivalently 24 times per day or 168 times per week or 1/60 times per minute.
Nov 14, 2013 | Office Equipment & Supplies
Sylvester measured his pulse and found that his heart beat at a rate of 80 beats a minute at rest. At this rate, how many days will it take his heart to beat 1,000,000 times?
First, figure out how many heartbeats in a day. We knowthere are 80 beats in a minute, 60 minutes in an hour, and 24 hours in a day.So, multiplying all those numbers together will give the heartbeats in a day: 80 beats 60minutes 24 hours ______ x ___________ x _________ Minute hour day
Cancelling the units and doing the arithmetic:115,200 beats/ daySo,at the rate of 115,200 beats per day, how long will it take for a million beats? That requires dividing a 1,000,000 by 115,200:1000000/115,200= 8.68055556 days
That is (almost exactly) 8 days 16 hours and 20 minutes.
Aug 01, 2011 | Texas Instruments TI-84 Plus Calculator
Water got inside and is npt working now,.
Any amount of water that reaches the interior circuitry will cause an electronic shortage. Disassemble the back of the calculator and place it on a cotton towel with the open side down, then keep the calculator in a heated area for about 2-3 hours to attempt to dry the water out. Replace the battery and attempt to power-up the device. If you get no power, then it would be relatively cheaper to purchase a new calculator rather than take it to an electronic shop for diagnostic purposes.
Oct 24, 2010 | Texas Instruments TI-84 Plus Calculator
How to change date and time on a sharp EL - 1197P calculator
Found Instructions for EL-1197PIII Calculator, think its the same thing
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position. Date: · Enter in the order of month, day and year, then press to complete the entry. · Use to separate month, day, and year. · When is pressed, the number entered is evaluated and displayed as “date” if the value is within the following range; “Error” is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: · Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) · If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”. · Use to separate hour and minute values. · When is pressed, the number entered is evaluated and displayed as “time” if the value is within the following range; “Error” is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Apr 06, 2010 | Sharp EL-1197P Calculator
I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
date is restored.
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Apr 27, 2009 | Sharp EL-1750PIII Calculator
Need to change the time on calculator
Date:
Enter in the order of month, day and year, then press date/time button
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
Date:
date is restored.
Time:
time is restored.
Aug 22, 2008 | Sharp EL-1750PIII Calculator
Excel calculations
Just enter using this style
TIME IN TIME OUT HOURS 10:00 16:50 6:50 10:22 17:34 7:12 9:00 10:00 1:00
the formula in HOURS is Time Out - Time In
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
