Question about Kenmore 63942 Dryer
Kenmore gas dryer model 110.77741600 Smells like it's burning everytime I use it
  • 460 Answers
You may need to replace the valve or the burner am sending you a diagram with all items you need including prices.
copy n paste this
The following will help you to fist check what you need to purchase.
copy n past the next video
If you need more assistance e-mail us back
Was this helpful?
Posted on May 13, 2009
4 Suggested Answers
  • 999 Answers
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Posted on Jan 24, 2010
  • 1430 Answers
SOURCE: I have a kenmore gas dryer, model 110-9644190. It
For a free video on diagnosing this go to
could be thermal fuse,thermostat,dryer coils,ignitor
Posted on Feb 26, 2010
  • 15935 Answers
SOURCE: Kenmore Elite HE3 Gas Dryer putting off an
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
LGR7647 will dry fine but smells like gass only when it runs.
make sure the air shutter on the gas nozzle isnt completely blocked or changed positions as the flame needs oxygen to make combustion complete otherwise the gas wont burn completely and you will get a black smoke that smells like raw gas
Dec 06, 2012 | Dryers
I bought this kenmore elite gas dryer in 2003. It has a burning smell inside the dryer. What can cause this?
check the belt on the drum for wear , if it smells like rubber burning,
Jun 08, 2011 | Dryers
Heat doesn't work. It is a gaz kenwood dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Mar 05, 2011 | Kenmore Dryers
Fabric looking belt came out of dryer. when i try to dry clothes it makes a loud noise and smells like something is burning and my clothes get twisted. how do i fix it? I have a kenmore 70 series dryer
Stop using your dryer in its current condition. That fabric looking felt is probably your drum seal. They commonly wear out. I will need your dryer model number in order to confirm how your dryer is configured and give you accurate advice on part numbers and directions on how to replace. The model number should be listed on a name plate around the door opening.
Apr 22, 2009 | Kenmore 63942 Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at
Oct 20, 2007 | Dryers
Kenmore 63942 Dryer Logo
253 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
