Want to use dual monitors with sapphire x1550
I want to use dual monitors in WinXP. Installed the Sapphire x1550 card but it has disabled the existing integrated video adapter on the motherboard so that it is not recognised in Setup.
As a result, I cannot set up the computer in dual view mode.
Is there a way to force the computer to recognise both video adapters?
  • jrawling Mar 08, 2009
    Software for the card indicates it does support dual monitor mode. I will attempt to remove and reinstall it
    Genius:
  • 1,066 Answers
No. if the integrated gfx are automatically disabled when you insert an add-on vidoe card,. then the internal gfx does not support dual monitor mode.
Posted on Mar 07, 2009
DRIVER FOR Sapphire Tech SAPPHIRE 100172-64L
Try this website, please:
http://www.drivermanager.com/en/drivers.php?Brand=Sapphire&Logo=sapphire&gclid=CISa6MqQ_LQCFQSg4Aod5icA1Q
Jan 22, 2013 | Sapphire Tech SAPPHIRE 100172-64L SAPPHIRE...
Trying to set up a dual monitor with onboard VGA and with Sapphire radeon x300 video card. The Radeon is taking over and not letting the motherboard vga work.
sir the mother board accept only one VGA card if you installed a new one the the other on will disabled if f you wanna run multi screen at the time just but the multi VGA dongle hub it is affordable and works fine dont need any driver buy it it`s useful affordable and have fun
May 23, 2011 | ATI Sapphire RADEON X300 SE 128MB DDR...
I have purchased a new Sapphire HD6870 card to replace an older and very loud HD4870. 1st I installed as normal and only the onboard graphics would work. 2nd Tried every trick in the book from updating...
Are you sure it's not a hardware problem, try putting it into one of your mates computer and see if it will work, otherwise it might just be a dud, sapphire will have to repair it for you. just to check, you have been using sapphire's drivers, and you have uninstalled then re installed ccc. try starting your computer in safe mode with the 6870 installed, just to make sure. and bye the way, Nice Card!!
Nik
Jan 23, 2011 | Sapphire RADEON HD6870, (1 GB) DDR5...
I have same problem
Download the latest AGP drivers for your motherboard. and install
Aug 04, 2009 | Sapphire RADEON X1550 Graphic Card
White screen on boot
this seems to be a problem with your graphic card, it may not be compatable with your system,or may not be fixed properly in your motherboard or it may be damaged as u said. I suggest get your card fixed or try it in someone else's computor to check if the card is fine or not.
Jul 27, 2009 | Sapphire RADEON X1550 Graphic Card
My computer won't detect ATI RADEON SAPPHIRE X1550 256MB
go to bios and enable it to detect graphics cards most bios have an option for onboard only or onboard and external graphics adapters
May 04, 2009 | Sapphire ATI RADEON X1600Pro 512MB...
My monitor shuts down on windows startup and it is only working in safe mode. if i let windows startup normally monitor just goes stand by. i have ati radeon x1300/x1550 series driver installed and if i...
these cards do require that additional power be given to them from the power supply. Have you connected the card to your PC power supply via the 3 pin connector and power connector.
Also uninstall the driver via safe mode and let it redetect in normal mode then install the latest drivers for your card. Download from ati.com
Mar 14, 2009 | Sapphire ATI RADEON X1300XT 512MB...
Blank White Screen.
cpu restart after first log on
Sep 06, 2008 | Sapphire RADEON X1550 Graphic Card
How to make use of 2 DVI outputs on Sapphire Radeon X800 GTO2 Graphics card
You need ATIs Catalyst Software to run dual monitors. Just installing the drivers is not enough. There is a bummer part of all this. Before you install the latest driver/Catalyst Crontrol Center, you will have to uninstall your current X800 software through Control Panel. If it fail to uninstall you will need to use ATIs uninstall software called: cat-uninstaller.exe. The first link below.
When you have the new CCC & driver installed you'll need to setup your dual monitors within the Catalyst Control Center. K
Uninstaller: http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
Radeon X800 Driver/CCC software: http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
1 last item. Please make sure your operating system is updated. ATI wants you to have .Net framework 2.0 installed before you install the driver package.
Dec 29, 2007 | Sapphire RADEON X800, (256 MB) PCI Express...
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
