Question about Nokia N70 Smartphone
My N70 is not charging when i connect to power.But it shows the charging indication. what can I do?
Kya kroo
Posted on Nov 14, 2011
    Problem Solver:
  • 4 Answers
You might have problems with the battery.try to watch if the batetery is standing good or is cxorectly putted in the device or your charger might have some problems on electonical part.Or the wire from your charger or entrerupt on a part and dosn't charge only when you put hem in a position.
Posted on Mar 07, 2009
  • Surjeet523 Nov 14, 2011
    Sir mere mobile se om 4.2ag 2011 operamini se song download nahi ho rahe hai
Nokia n96 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 17, 2012 | Nokia N96 Smartphone
Tip
How do I find if my iPod touch battery is dead?
<p>When the iPod touch battery dies, you cannot do anything with the device. You will receive a warning on the screen of the iPod touch, when 5 percent of the battery turns on the device. Connect the device to a power source as soon as possible to load and prevent the battery goes dead. When the battery dies, the unit will shut down and will be connected to a power and charged before you can use <br /> <p><br /> <p>1. Press the iPod touch "Sleep / Wake" button, located along the upper side of the machine. If your iPod does not care, this is an indicator that the battery is dead. <br /> <p><br /> <p>2. Connect a charging cable to charge your iPod and connect the USB cable to a power of high power. High-power USB ports directly on your computer tower or, if the hardware usually found in the tower on the monitor, the monitor itself. The iPod touch screen shows a big red battery icon on the far left of the icon, indicating that the battery was empty. <br /> <p><br /> <p>3. Press the "Sleep / Wake" to see if the iPod is connected. If so, check the battery life, looking at the battery icon in the upper right corner of the screen. When the icon appears white, the battery is full when the icon is half black, the battery is almost dead, and if the battery is almost dead, you will receive a warning. If the iPod does not start, the battery is completely dead. In this case, your iPod into electronics store and have the battery replaced. <br />
on Aug 05, 2011 | Computers & Internet
I am unable to watch online video on my nokia n70 hand set music edition. symbian s 60 software. when i open vedio on youtube real player open and shows ''define connection ***** point first'' please...
please help.......
Jul 01, 2010 | Nokia N70 Smartphone
The USB connected screen is frozen on my reader and I don't know how to fix it.
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred. Please perform the below mentioned steps and check whether it helps. Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure. 2. Perform a soft reset. Just press the RESET button using a sharp-pointed object 3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup. 4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again. 5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding. 6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset. 7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off. * It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E. 8. Once the Reader has sufficient charge, perform these troubleshooting steps again. 9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status: * You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged. * It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired: http://eservice.sony.com
Jan 02, 2010 | Sony Reader Touch PRS-600
I have had this charging overnight but it won't charge. What should I do?
Hello Friend,
It depends on what you mean by charging overnight.
1. When you connect the charger, it shows on the phone that it's charging but after a while if you unplug the charger, it's still not charged: if it's the case, that means the battery is dead and needs to be replaced.
2. When you connect the charger, it doesn't show the phone charging: in this case it can be the charger brocken or the phone charge connector is faulty. you can verify that by moving the charger connector a little bit and see if it will start charging, if not you can try with another charger. if it doesn't charge even with another charger, at this time i will say for sure that the phone charge connector is faulty and needs a repair.
Best Regards,
Oct 30, 2009 | Toshiba e310 Pocket PC
Same Problem
Your best bet is getting a new battery! I had this issue at about the 2 year mark and it started out of the blue. The battery would show fully charged and then all of a sudden while I am talking I start hearing some static and then the person on the other end could no longer hear me and the phone would go dead. I would have to take the battery out and put it back in for it to even power back on. When it did power back on (if it would even do so) the battery charge indicator would show red indicating no battery life left. To be certain this is the issue I would suggest keeping your phone plugged in to the wall/car charger while you are using it and see if the static auto turnoff issue happens while it is connected to a power source. It should not disconnect on you while connected.
I also noticed that the battery appeared to be a little "puffy" like one of the cells within the battery itself may have imploded and shorted out if that makes sense. Good Luck.
Sep 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Nokia N70 doesn't charge.
Either your charger port has got damaged due to moisture or your charger is not working properly. Go to the Nearest nokia care centre (service centre). They will solve your problem in seconds.
Jul 12, 2009 | Nokia N70 Smartphone
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Charging Battery
did u try to charge it connected to your pc? maybe its the charger
Feb 04, 2008 | Motorola Mobility Moto Q
I-mate PDA2k
To be sure if its not the battery thats bad, connect it to the charger and charge for a while. Monitor the light indicator at the top right of the phone.It should start from red to green after its fully charged. then try to restart it by turning on the power button also at the top right of the phone.
If after these procedures the phone does not start up or it shows some temporal 3 seconds flash of power, you may need to get another battery. If a new battery does not start your phone,then its a power fault.It needs to be rapaired.
Aug 11, 2007 | i-mate PDA2k Pocket PC
Nokia N70 Smartphone Logo
112 people viewed this question
Top Nokia Computers & Internet Experts
Clive Gray
Brian Sullivan
Brian Sullivan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
