Question about Acer Aspire 5315 15.4-inch Notebook PC
Hi when i plug in the chargr on my acer 5315 red power light and
And red flashing battery light,and it will not start.thanks
  • 1 more comment
  • sushi473 Mar 07, 2009
    no lights wont start
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    ur batt is faulty try changing it
  • Rob
    Rob May 11, 2010
    What happens if you remove the battery, hook up the power cable and try to start the computer?
The Acer 5315 notebook I have will not power up. It is plugged in and when I press the start button, the power light is on for about 2 seconds and then it shuts down. I removed the battery and it will not...
most probably it is the motherboard. try to turn on the computer using the ac adapter without the battery. if the problem is the same, the motherboard is already defective.
Jun 11, 2010 | Acer Aspire 5315 Notebook
The laptop 5315 is not charging , no red glow
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 12, 2010 | Acer Aspire 5315 Notebook
Acer Asipre 5315 laptop Battery A/C supply plugged in, hit power switch and the power light blinks 2 (maybe 1 time)times but the unit does not power on.
remove the battery and power cord then remove the battery on the mother board, hold down the power button for 60 seconds to drain the capacitors, if that doesn't work it's the motherboard that should be replaced.
Feb 19, 2010 | Acer Aspire 5315 Notebook
When i try to charge my notebook 2 red lights come on flashing
check your battery pack! it can be defective also check the internal power supply to make sure it isnt crack away from the motherboard which is very common
Jan 13, 2010 | Acer Aspire 5315 Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Acer 5315 Battery cHarging Problems
All rechargeable batteries have a limited life, and as they age their charge capacity reduces over time and you get shorter and shorter time between charges.
Recharage batteries have a finite number of charge and discharge cycles and batteries over 2 years old are considered nearly worn out. Worn out batteries won't charge up at all.
Jun 30, 2009 | Acer Aspire 5315 Notebook
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
My acer aspire 5315 doesnt boot up the power
remove the battery and plug in power..if it works then your battery having problem..if not then ur power adpter having problem...
Apr 20, 2009 | Acer Aspire One PC Notebook
ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
Dec 20, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 15.4-inch Notebook PC   Logo
147 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
