Question about Sony Handycam DCR-TRV530 Digital Camcorder
My DCR-TRV530 Digital 8 camcorder got stuck, the tape is half way out but it does not pop-out and I can't take it out
  • 423 Answers
If the tape is wrapped around a head or caught in a pinch roller, then you may be able to remove it with your pen. Underneath the tape is a small hole. Insert a pen or similar object into the hole. This will let you disengage the spindles in the tape. You have to hold the pen in the hole to keep them disengaged. You can then pull out the tape cartridge. This will let you see inside and whatever may be holding the tape in. Hope this helps.
Rob
Posted on Mar 07, 2009
  • Rob
    Rob Mar 07, 2009
    I'm sorry is this not the solution to your problem? How is the tape stuck in the unit?
    Rob
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Does not record video but records audio. will
Pushed the reset button under the flip out screen and viola it worked AOK.
Jan 04, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
When transferring (or watching) video from this Sony DCR-TRV530
Sounds video head is dirty / clogged.
Use good quality video-8 head cleaning tape for head cleaning in DCR-TRV530 and then record and playback it.
Aug 23, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony TRV530 has cassette holder stuck half way out
Thats an interruption of the ejection process, either you push it, you were on low battery, the energy was interrupted or you leave the camera in a car and th heat/cold affects it. Try to cheat/reset the camera system: Remove the clock cell, remove the battery or ac/cord at the same time you push the eject button once. Wait for an hour. Place the clock battery. Connect the AC/Charger cord or the battery (it MUST be completely charged). The camera will reset, check out and complete the ejection.
Jun 24, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Error code C:31:42 on a Sony Digital Handycam DCR-TRV530
Here is the solution to your problem:  C:31:42 = FG (film guide) fault during normal drum operations. Load the tape again, and perform operations from the beginning! Hope this helps.
Fotobean
Jan 19, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony DCR-TRV530 firewire connection not recogized on Mac; won't import or capture video
try to use USB wire and then install the driver to your pc. hope that helps you!
CHARCOIS
Aug 21, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
Error code on DCR-TRV530 - C:32:10
Try taking out the battery and plugging in the charger with no battery. That did it for me.
Jan 26, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
Playback of my 8 mm tapes on camera
Hello, there can be some contact errors at the flat cables and connectors from the mechanism to the main board. Please contact your nearest Authorized Sony Service. Best regards, Arpi
Dec 13, 2006 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony Handycam DCR-TRV530 Digital Camcorder Logo
179 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
