Question about XM Radio (XMP6000)
I wired a roadie xt on my ultra classis and it cuts out/no signal often. Will wiring it to the back antenna in addition to connecting to the receiver help or solve the problem?
The antenna has to be completely visible to the sky. We haqd the same thing happen. Installed it on the trunk lid and it works great.
Posted on Jun 09, 2009
I have a Roady in my car and recently I have been getting "no signal" and "loading" on the display....I moved the antenna to the center of the roof but it hasn't helped...Could my antenna be bad? Is there...
It is surely the antennae. I have had to replace mine a few times too. The thing is, where it bends, like near the plug connection and near the actual antennae wire connection, it just fractures a bit and that's it.
Pick yourself up a new one on eBay or Amazon, and no, there aren't really heavy duty ones and that wouldn't fix it, it is the wire getting worn.
Apr 02, 2010 | Delphi Roady XT XM Radio Receiver
Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
Nov 17, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT will not maintain signal
if you plug and unplug your antenna connection to the receiver a lot it loses the ground(shielded) line connection, if your lucky you can take a safety pin and CAREFULLY bend the radios 4 outer shell antenna contacts inward to make contact with the antenna connector, if its the plug on the antenna,try pushing wire in toward plug connection to the radio...delphi never had much for life on any external products that fit their XM radios but when you need repl parts boy are they waiting for you, and they got them
Aug 30, 2009 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
Roady xt Antenna Problems
when it reads antenna it means there something wrong with either the connection or the antenna itself, it could be the location of the antenna or the antenna is going bad. if there is no obstructions on the car blocking the antenna i would advise purchasing a new antenna. you can get one at http://shopdelphi.com/consumers/satradio/xpressrc/
Feb 07, 2009 | Delphi Roady XT XM Radio Receiver
Antenna not working
Did you try to wiggle or remove and reinstall the antenna by the connection? sometimes that works. Are there any frayed or exposed wires on the antenna cable. You may have a short.
Jan 04, 2008 | Delphi Roady XT XM Radio Receiver
"Antenna" Appears on Roady XT Display
I had the same problem, it says antenna when you turn it on. It seems that there is a small wire that stays in the radio side of the socket right in the middle of the socket. This fine wire breaks off . I think there is no known repair for this. I took a piece of fine wire from a wire brush, and poked it into the socket . Had to get one that was thick enough to stay. Then I plugged the antenna into it, it worked.
Nov 23, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Car Audio & Video Logo
59 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
John
John
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
