I connect the management port of controller B of IBM totalStorage
DS300 with a cross cable to a linux machine.
According to DS300 docs, the default IP address of controller B is
192.168.70.124/255.255.0.0.
see 4.4.1 Setup of management ports of TotalStorage DS300 and DS400
in
IBM TotalStorage - DS300 and DS400 / Best Practices Guide.
So I set the linux ip address to 192.168.70.1/255.255.0.0.
while pinging 192.168.70.124 , I power up controller B of
IBM totalStorage. I tried three times this power down and
power up; I get some answers for this ping (about 4 or 5)
and then there are no answers. Also of course there is no
telnet to 192.168.70.124.
Could it be that someone had changed the IP ?
an in case it is so - how can I see the real IP address ?
Regards,
Ian
Rating: 0%, 0 votes
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
I connect that DS300 directly to a linux machine. These 2 machines are
not connected
anywhere else.
And I also tried the following:
the same on connecter A
Pinging ALL ip addresses in the range 192.168.70.0-192.168.70.255.
and none answered (except the linux machine).
Any ideas?
Ian
Rating: 0%, 0 votes
You say you get some responses to the ping and then you don't. Who could
have changed the IP in those seconds? Do you have a DHCP server? If so,
check the leases file. Otherwise, I think this could be a firewall
problem or the storage device may be defective. Does this device have
only a telnet interface and not a web interface? Did you try browsing
The early bird who catches the worm works for someone who comes in late
and owns the worm farm.
-- Travis McGee
Rating: 0%, 0 votes
If the thing follows the common practice of probing its
own IP at start with gratuitous ARPs, get an Ethernet
sniffer (tcpdump, Ethereal, Tethereal or Wireshark) and
look for ARP packets with the proper MAC from the IBM box.
HTH
Tauno Voipio
tauno voipio (at) iki fi
Post a New problem for IBM FlashCopy Option for DS300 &
Email this problem
Can you Help with these Network Management Tools problems?
drag nat spk med solutions 8
