Question about HP Deskjet D1420 InkJet Photo Printer
Printer keeps stating paperjam but there is no paper in it
    Scholar:
  • 53 Answers
Check the back of the printer. There should be a removable rear panel. Just Pull back on the lever (I believe on the right side) The rear panel will come off. See if any paper is lodged along the paper feeder wheels, if so, just remove it.  Also check back in the front of the printer and make sure there is none lodged along the feeder there where the paper normally comes out.
Power the printer back up and try to print again.
Hope this helps
-enov8
Posted on Mar 07, 2009
Paperjam siplay no paper in the back
hi open your printer so that you can see the wheels that feed the paper into the printer and check that no paper is stuck in the meconisom is this is soum times wey it says paperjam
Apr 09, 2014 | Kodak ESP 3 Multifunction Printer/ Copier/...
The amber light with the triangle next to it is flashing please help!!!
That is the ATTENTION state. Four things can cause it to flash.
1) empty paper tray
2) door open
3) paper jam
4) misfeed from tray.
Press the GO button(the diamond). If it still doesn't work, check for a paperjam.. Also try printing from the manual feed tray.
Aug 21, 2010 | HP LaserJet 1160 Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
My NP6012 stops and paperjam light comes on. Paper not being fed.
Pick up wheels can be full of dust due the time storage.Keep on trying to make copies,the paper will clean the rollers every time it try to feed.
Jan 28, 2009 | Office Equipment & Supplies
Kyocera paperjam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
Locked on `paperjam
I do not need the premium plan . please understand. I DO NOT HAVE A TV PROBLEM.
my request was for a problem with a canon printer . your suggestions were of no help . it is now in the hands of a repair shop. I trust that you will not charge
for the uncuccessful attempt .
Edward.
Oct 02, 2008 | Televison & Video
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Mfc-5460cn
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
HP Deskjet D1420 InkJet Photo Printer Logo
168 people viewed this question
Ben Johnson
