Question about Canon LBP 800 Laser Printer
Printing problem of my hp 2015 laser printer
1. when i get print command print come out blank
2. paper proper heatup i checked it
2. tooner also replaced with other printer but problem still
3. laser assembly shutter open properly
4. what is the problem please tell me
  • 101 Answers
It may be poor contacts on printer cartridge holder. Try to clean all electrical contacts inside depending to cartridge.
Posted on Mar 07, 2009
My Hp photo printer C420 takes the command but prints out blank pages
check transfer belt a cartridge some contact bias plate laser unit some posssibilities isolation
Feb 19, 2013 | PrintCountry HP Photosmart C4200 Series...
Way printing blank in hp 2727nf
Hello ,
It seems
1 Your shutter lock may be damaged.(laser shutter)
2 tooner may be empty.
jm
Nov 11, 2011 | HP M2727NF Laserjet Printer
I have HP1320 printer when i send the print command printer paper out blank no printing?
1-There is a plastic knob that press the laser unit's shutter at the front door check and make sure that it is OK .
2-there are some earthing wire, at left side that connect with toner,some time these wires pressed down and not connected with toner and the print comes blank.
Jul 10, 2010 | HP LaserJet 1320 Printer
When a print a page the page comes out blank
1 check the flap of scanner which pushed by door .
2 check the grounding of printer which charged the tooner drum .
3 dc controler unit may be faulty.
Jul 02, 2010 | HP LaserJet 1320 Printer
Hp laser jet printer p2015d printing blank pages even after a new toner
first confirm it that u hv pull out the strip from the tooner
second the tooner sitted properly pls check the grounding connectors touches the tooner properly.
third one the suttor of scaner *** not open properly call hp engr for this problem.
May 05, 2010 | HP LaserJet P2015dn Printer
I get blank pages when printing. Sometimes all pages are blank, sometimes first and last page print, with blank middle pages.
hi,check your printing setting and then print.
or....
uninstall the printer then install the printer again then printer has default setting and print the paper.
sometimes printer current pages print wich is selected by setting.you must select all the pages.
to change the setting,,,
1-open control panel then open printers and faxes then check seeting.
Apr 12, 2009 | HP DeskJet 842c InkJet Printer
Lazer not scanner
If I am not mistaken you are getting blank paper when you give printing command am I right if yes........
every laser printer has one data scanning and transferring data to toner drum unit in it.
BLANK PAPER PRINTING PROBLEM ONLY LINKED WITH
1. TONER CARTRIDGE PROBLEM OR
2. SCANNING UNIT OF YOUR LASER PRINTER PART OF YOUR LASER PRINTER.
CHANGE TONER IF PROMLEM IS SAME THEN IT IS CONNECTEE TO SCANNER OF YOUR LASER
IF NOT SOLVED MAIL ME TO inkcity@rediffmail.com
Jun 01, 2008 | HP LaserJet 1012 Printer
HP LASERJET 4PLUS PRINTER-PRINT OUT BLANK PAPER AND WITH ERROR MSG 41.3
Get a new printer.
Serious if it is happening repeatedly and it is not because of corrupt data like a bad file being sent to it, then tis biga buckas any way you go, replacing the laser or the Main Control Board. From your description it will be laser, laser units wear out because inside is a little motor working real hard and eventually they wear out or main board the brains behind the operation has lost the plot
here is the code description from manual
41.X Printer Error
A temporary printing error has occurred. The page containing the error will automatically be reprinted. If the error persists:
1. Reseat the connections to the laser scanner and then to the engine controller board.
2. Replace the laser scanner.
3. Replace the engine controller board.
Nov 20, 2007 | HP LaserJet 4 plus Printer
Printing blank paper
three possible problems,
1 did not pull out strip from cartridge
2 HVT gone bad
3 contacts on cartridge or printer has a problem
Oct 11, 2007 | HP LaserJet 6L Printer
Canon LBP 800 Laser Printer Logo
62 people viewed this question
old marine
old marine
