Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel gwl11 want power on
The washer will not power on... this started after finishing a load of cloths which still had suds on them... the spin cycle seemed slower than normal... So were tried to put the cloths back on the rinse cycle to rinse again and the machine would not come on... wouldn't say a word... since have noticed a little puddle of water underneath and some corrosion on pump... We tried unplugging and plugging back in as the manual stated to try but it still did not come on... Outlet still good tested w/ another appliance... It worked fine... Please help... What could it be...
Start of by replacing your drain pump. if there is still no response to the electroncs you will need another power supply. the pump took the electronics out. ???
Posted on Aug 14, 2007
SOURCE:
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Need instructions on taking machine apart
This is a good place to get a parts manual.
Parts manual F&P
Dec 13, 2013 | Fisher and Paykel GWL11 Top Load Washer
Hi i was just wondering how to clean the filter on a fisher and paykel washing machine. when washing clothes the washer doesnt seem to be getting them as clean as they could be and there is always debree...
There is no filter to clean on GWL11. There is an optional lit filter that can be installed that goes in-place of the fabric softener cup. I would guess that the reason debree is being left behind is possible due to the over use of soap... This is a high efficiency machine and if you are using the auto water level option it may not be using as much water as you believe it should (or would). The debree get suspended in the soap suds as the should however, there is too many of them and they are not all being rinsed out. You could try using the fabric softener rinse option even if your not using fabric softener this gives it a more traditional rinse like most other top load washers use.
For really soiled clothes like sand and dries mud etc. shake the clothes out first.
I hope this helps.
P.S. I actually have this exact washer myself.
May 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
When washer finishes cycle and spins out water will start dripping into the washer and will get the clothes wet if not taken out
You have a faulty water inlet valve which needs to be replaced. If it's cold water dripping into the machine then it's the cold water inlet valve.
Oct 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
193 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
