Question about Alpine iDA-X001 CD Player
Alpine ida-x001 volume is low even if stereo is turned all the way up only when ipod is plugged in on ipod setting.Radio (AM/FM) is normal volume (louder)..How can I fix this?
  • guitargod121 Mar 07, 2009
    I cannot adjust the level on the ipod itself because once you plug it in to the alpine/ipod cale it disables all functions on the ipod. I am farmiliar with "level balancing" and this is what I was looking for. Unfortunately havn't had any luck. I've had the head unit for over a year with no problems until 2 days ago, when I noticed the volume problem. It's almost a if I bumped a button somewhere. When the ipod control is activated on the head unit the volume is alot lower than previous. I do beleive we are both on the same page with your solution..
  • 463 Answers
Most newer car receivers have a feature named something like "level balancing" in which you can adjust the relative loudness of each input (Tuner, CD, AUX, IPOD). Check you owner's manual for a similar function.
Also, are you or can you turn the level of the ipod itself up a bit?
Posted on Mar 07, 2009
96 Marquis LS Poor am radio reception
Do you have the BLUE power antenna wire hooked up?
If not it may help your issue
Jun 12, 2013 | Alpine Wire Harness Ida-x305 Ida-x303...
Tip
Connecting an iPod Without a Car Stereo
<p>Newer cars often come with adapters to connect an iPod to a car radio, but you can still listen to your favorite lists, if you do not have a car stereo at all. Portable electronics can be used to connect the iPod to speakers, and play it on your car. <br /> <p><br /> <p>1. Purchase an adapter FM radio transmitter for your iPod. It will stream music from your iPod to a low-frequency power, which can be captured by a radio in your car. For best results, use a transmitter with a power adapter 12 volts, you can power adapter car "cigarette lighter" power outlet instead of batteries. <br /> <p><br /> <p>2. Place a "boom box" radio in your car stereo. For purposes of the iPod, the older model, if you have done. All you need is a working radio and decent speakers. Again, it is best if you turn the car to avoid the use of batteries. <br /> <p><br /> <p>3. Set your transmitter to a radio frequency is not used in the stereo field, and tune the same frequency. Adjust the volume on the stereo halfway. <br /> <p><br /> <p>4. Place your iPod within reach of the driver or passenger. When the iPod is playing, the sound will be transmitted to the radio. You can adjust the volume on the iPod itself to control the music changing. When the iPod is off, the radios go silent, although you will hear a static noise. Turn on the radio to get rid of noise, and to save battery when not running the car's power. <br />
on Aug 09, 2011 | Apple iPod touch
Is there an adapter I can purchase to be able to play an IPOD with my alpine cde 9841 car cd receiver stereo?
Your headunit doesn't have the option of a plug i Ipod cable, The only way to use it with your stereo is to get an FM Transmitter and you tune into the ipod through the radio.
Mar 06, 2012 | Alpine CDE-9841 CD Player
Cant play ipod after iphone upgrade to ios4.2.1
Check with Alpine for and update for you radio
Feb 16, 2011 | Alpine iDA-X001 CD Player
Is there a way to plug my iPod into my 2005 Saturn
YOU CAN GET A "STREAMING BLUETOOTH DEVICE , PARROT OR IQ, AND A BLUE TOOTH DONGLE FOR THE IPOD, THIS IS INSTALED IN THE TRUCK AND WORKS BETTER THAN THE FM GADGET
Dec 07, 2009 | 2005 Saturn ION
Low audio from ipod through alpine car stereo
in your menu, turn up i-pod audio level. if that doesn't work, check cable.
May 06, 2009 | Car Audio & Video
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Alpine iDA-X001 CD Player Logo
226 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
