FixYa.com
Tags:
IBM DS4800 Linux/Intel Host Kit
"Cluster Join" takes about 7 minutes
By Lizzy - usenet poster
Hi!
We justed moved our five node Netware 6.5 SP6 (post updates MM65sp6 and
WSOCK6k) cluster from IBM SVC (IBM DS4800 attached) to native DS4800 mode.
We changed from SDD.CDM fault tolerance to DS4800 (LSIMPE.CDM)and
swiched "set Multi-Path Support = ON".
We are using QLogic QLA2310F (2GBit) and QL2360 (4Gbit) Adapter, the
load balancing of the Qlogic driver is switched off, the drivers are
current (6.90o), BIOS also updated.
After moving to DS4800 (two fabrics, four pathes to the storage, port
based zoneing) the cluster join takes about 7mins, after that, the
resources are up and running fast.
Any ideas?
Regards,
Holger
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Pasty
Pasty - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi!
I just reduced the HBA??s to one and the join speed was down to the half
(3mins) not to 5-15sec.
Do you think the problem lies in LSIMPE.CDM?
Holger
Tim Heywood NSC SYSOP wrote:
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
It's also been the default for several SPs now, so it probably is
literally "no change" to set in your startup.ncf. ;-} My cluster is
running on a Hitachi array, but I've seen the non-clustered 2107 (a
DS4800, I believe, as it shows in the Inquiry String) run very fast when
the cache has been full; performance while filling the cache wasn't quite
as high, so try rebooting several times and see if it speeds up =8-o
/dps
Using Opera's revolutionary e-mail client: #
Solution #3
Not Rated (0)
kcw573
Rating: 0%, 0 votes
Hi!
Me too :( scsihd aen is in STARTUP.NCF.
Holger
Solution #4
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
Been there - no change :-/
Tim
Tim Heywood (SYSOP)
NDS8
Scotland
(God's Country)
In theory, practice and theory are the same
In Practice, they are different
Solution #5
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
I did an IBM san a year or so ago and working with the ibm testing people
in Calafornia the advised me to use the following command
in Startup.ncf
Load scsihd.cdm AEN
This enables async event notification for the ibm devices. The box was a
fastT type but maybe worth a test at least.
Lee Smith
ANS Group
Solution #6
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
I have yet to find a happy solution with a DS4800 and multipath
I agree with the patching, and I have tried long and hard to get speed
and multipath working - to no avail... This has been with IBM
helping.
So, I would say, reduce to one HBA and test the join time. If much
faster, start shouting at IBM. If enough of us do that maybe they
will fix it!
Tim
Tim Heywood (SYSOP)
NDS8
Scotland
(God's Country)
Can you Help with these Network Management Tools problems?
dhcp relay source code
Hi , I am in very much need of... Answer This...
drag nat spk med solutions 8
Vista new computer - message... Answer This...
sagem my850c need solution
Dear sir. i got gift from... Answer This...
how to connect landline phone...
I want to connect landline... Answer This...
reparing apple ipod
do not display mp4 player Answer This...
Repair Service
Find Network Man. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
