Question about iRiver E100 Digital Media Player
How do I delete files from the internal memory?
Under internal memory I select a file and hit the right tab and I get an error message "cannot delete file in mtp mode"
How can I delete files from the internal memory without reformating the drive?
  • Anonymous May 04, 2009
    ditto
    Problem Solver:
  • 9 Answers
When that happened with me, I plugged it in my computer and just deleted it there. I think that worked. Or that was why I switched the whole thing to "mass storage device" and left it that way. It was easier.
Posted on May 07, 2009
BROWSER COOKIE FUNCTIONALITY IS TURN OFF. UNABLE TO TURN IT ON
A cookie is a string of information that is sent to your computer from each website that you visit. Cookies are harmless. Why would you want to delete them then? The reason you would want to delete cookies from your computer is that they can store information such as user name, IP address, password, email address, shopping cart items and any strings of information that can be related to your identity. Cookies that are on your computer may slow your computer down. Therefore you may want to delete cookies from your browser. Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies.
You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted
Hope this helps
Dec 31, 2012 | Computers & Internet
I had google chrome, then i uninstalled it. now i want reinstall and i get message:assembly is not installed on your system (Exception ffrom HIRESULT:0x800736B3)
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have other web search toolbars interfering
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
also b> http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then delete cookies Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted. b> Hope this helps.
Jul 29, 2012 | Microsoft Computers & Internet
LOW MEMORY
Hi Yeyek0905,
Good day!
I understand that your computer is running on Low memory.
If you have budget, it would be best to upgrade your RAM but then you may try the following solutions below:
For Low Virtual memory on Windows XP:
1. Click Start, then open the Control Panel.
2. Select Performance and Maintenance, and then click System.
3. Click the Advanced tab.
4. Under Performance, choose Settings.
5. Click the Advanced tab.
6. Under Virtual memory, click Change.
7. Under Drive [Volume Label], click the drive that contains the paging file (virtual memory) settings that you want to change. In almost every case, this will be your C: drive.
8. Click to select the "System managed size" option, then click Set.
9. Click OK three times and restart your computer
For Low Virtual memory on Windows Vista and windows 7:
1. Click Start, then open the Control Panel then select on Systems.
2. Click on advanced tab and select on settings for the performance option.
2. Select o the advanced tab then check on Virtual Memory(Change).
Uncheck the "Automatically manage paging file size", and select 'Custom Size'.
Increased the size based on the Recommended levels+200mb
You may also do the following to free up some space:
1. Delete Temporary files
a. Click on start and type in %temp% on the run option.
b. Delete all your temporary files.
2. Do a disk clean up.
a. Click on Start
b. Accessories
c. System tools
d. Select on disk clean up.
I hope this helps.
Best regards,
Jheycie
Jan 02, 2011 | Computers & Internet
HOW DO I DELETE FILES
deleting files on sd cards is the same a deleting any other file on a computer as long as the media is not protected against file deletion or file altering
usually sd cards as you used to find also in old floppy dics, have a tab or switch you need to set accordingly to allow file overwriting. inspection the sd card and make sure that the tiny switch or lock is in the off position, reinstall sd card in the reader or sd card drive and attempt to delete files by selecting them and hitting the del key or simple selecting them and right clicking to then select delete.
if the tab is in the off position try it in the "on" position and see if deletion can be accomplished. if neither works your sd card may be defective. contact the provider and have the warranty honored accordingly in within the warranty terms.
May 06, 2010 | PNY 4GB Secure Digital High Capacity...
When I go on-line, I receive this message ''RUNNER FILE ERROR''
Probably was uninstalled already. 2 solutions:
1.Right click on My Computer select Explore
Select C; click explore again
Select Program Files folder, explore
Find the kodak Program and Delete
the folder.
2. Go Start y type MSCONFIG in RUN or Search
hit enter, a window will appear on
your screen in the tab "STARTUP"
un-check the line that contents
Kodak application. Press OK and
Re-Start the computer.
Apr 10, 2010 | Computers & Internet
I have nokia n73. there is a problem in its use. whenever i use it , it gives the message of memory full and asks me to delete some data. please tell me some solution.
The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
Memory Card Formatting Procedure
  1. Go to MENU > TOOLS > MEMORY.
  2. On the memory card menu press OPTIONS.
  3. Scroll to Format memory card.
  4. Press Select.
  5. Select Yes
  6. Once the formatting is complete, remove the memory card.
Phone Memory Formatting Procedure
  1. On your phone dial *#7370#.
  2. Press Yes then enter your phone lock code. Default code is 12345.
  3. Formatting is complete when the phone restarts. Insert the memory card and format it again.
Jan 15, 2010 | Nokia N73 Cellular Phone
Files cannot be deleted or moved to the device because "the device has either stopped responding or has been disconnected".It is a Sony NWZ E436F.
Reset the Walkman by pressing and holding the Reset button for 30 seconds. Then, try transferring or deleting any files from it. Furthermore, if the issue persists then try formatting the internal flash memory.
Follow the steps given below to format the internal flash memory of the Walkman:
Press and hold the Back/Home button in the Pause mode until the Home menu appears.
Press the up/down/left/right button to select Settings, and then press the >|| button to confirm.
Press the up/down/left/right button to select "Common Settings," and then press the >|| button to confirm.
The list of "Common Settings" options appears.
Press the up/down/left/right button to select "Format" and then press the >|| button to confirm.
"All data including songs will be deleted. Proceed?" message will appear.
Press the up/down button to select "Yes," and then press the >|| button to confirm.
"All data will be deleted. Proceed?" message will appear.
While the memory is being formatted, an animated display appears. When initialization finishes, "Memory formatted." message appears.
Aug 24, 2009 | Sony NWZ-E436F MP3 Player
Stuck on loading your personal settings it is so slow
try this press ctrl alt delete when loading your personal setting
Jul 10, 2009 | E-Machines eMachines Desktop PC
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
Accidentally deleted photos from internal memory of my Kodak came
Hi!
Let's try to save your son's halloween pics.
There are a lot of recovery software that you can use to recover deleted files - specially pictures. You can try to use Zero Assumption Recovery. You can download the software at this site:
http://www.z-a-recovery.com/download.htm
It's a free software (you do not neet to pay to use this), and it's easy to use.
Here are the steps that you need to do:
1.) After you install this software, connect your camera to your PC (do not insert the memory card). Turn on the camera, open the Zero Assumption Recovery software.
2.) Click Next. Select "Recover images from the digital camera.." and click Next again.
3.) Select the Physical Device - select your camera , click Next. [grab a cup of coffee since retrieving the files may take some time depending on the size of the memory (",) ]
4.) After retrieving the files - select all the files that can be recovered. Click Next.
5.) Select the button on the right side (close to Destination) and select where you want to save the files. Click "Start revovering files".
That's it.
I hope that helps.
Good luck and have a nice day!
Nov 20, 2008 | Samsung Digimax S500 Digital Camera
iRiver E100  Digital Media Player Logo
169 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
