I have two computers running XP service pack 3 connected wirelessly to a adsl modem/router. They both access the internet without problems but I would like them to be networked to share files and printers. No matter how I try to set up a wireless network it never works. I have no trouble if I connect to the router with cables.
  • 3 more comments
  • vinnyt53 Mar 07, 2009
    I do not understand the previous advice.
    My wireless ADSL2 modem/router is a D'Link-2740B (Rangebooster N) and my network adapters are D'Link DWA-547 (Rangebooster N). I had the same problems with previous wireless equipment and never did get it fixed. Iam running AVG Internet security on one computer and AVG Free antivirus on the other.
    It's no use setting file sharing, the computers never find each other to share anything. They never connect in any way wirelessly. I have no trouble connecting and sharing if I use cables to the ethernet ports on router
    I have checked all of the settings metioned except for manual setting of ip addresses, I will try this later.
    I was already setting up my network correctly so it was starting to look like your advice was usless as everything worked fine with cables but when you mentioned firewalls I checked the settings again and there was one refering to my wireless network as unsafe. I changed it to safe and now it all works. I love to learn more about this stuff.
    Thanks,
    Vince.
    Genius:
  • 1,550 Answers
Go to control panel ->network connections ->lan .
Disable LAN connections.
And try for sharing .
Also Check for any virus in both systems . Sometimes virus blocks sharing of networks .
Posted on Mar 07, 2009
  • 4,472 Answers
Http://www.microsoft.com/windowsxp/using/networking/setup/homenet.mspx
This link has the step by step instructions. If you need any further assistance let me know. Also please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, some checks that you could consider/try:
  • verify that both computers belong to the same Workgroup (Control Panel, System Properties, Computer Name);
  • verify that at least one folder on both computers is shared;
  • verify that
  • 'Automatically search for network folders and printers' is checked (Control Panel, Folder Options, View tab);
  • set the IP address manually/static.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Mar 07, 2009
    Would appreciate an update on any developments at your convenience.
    Cheers.
  • 32,281 Answers
You have to turn on file sharing on both computers on the C drive drive or on specific folders on the c or d drives (if you have a 2nd hard drive.
If you want to share the whole drive then :-
Click on My Computer - then right click on the C orD drive - click on Sharing and Security, click OK - then on Network Sharing and Security tick Sharring and Security - then enter a share name (use a name that identifies this drive and computer). - click OK
Then go to Control Panel - right click on your Wireless Network Connection - tick File and Printer Sharing for Microsoft Networks - click OK.
Repeat these steps for the other computer.
If you only want to share specific folders then go to the folder that you want to share and enable shareind on the folder/s only.
You will be able to see the drives or folders on the other computer by going to My Network Places.
  • Chris Hingee
    Chris Hingee Mar 07, 2009
    The computers must be in the sameworkgroup.
    Configure the computers to have the same workgroup name.
    Go to Control Panel - System - Computer Name.
    Name each computer with a unique name and the same Workgroup name on both computers.
  • 408 Answers
Sounds like a firewall issue or security setting in the router.  If you are sharing the folders properly, then I don't see a problem with the computer itself......wait a second..i just remembered something..lol...make sure you go to your control panel and network connections and right click>disable your lan connections.  Lan take priority over wireless.  I remember I ran into that a few years back and that fixed the problem.  make sure you do it in both computers.
  • 2 more comments
  • Shadow1989 Mar 07, 2009
    BTW, by lan I meant the one for the hard wire.  The only one that should be enabled is your wireless conenction.
    avg should not affect it.  I am running those on my computer with no problems filesharing.  Did you try disabling the ethernet port, not the wireless on, but the hard wired ones in both computers in the control panel?
    also make sure you have file and print sharing services installed on the properties tab of both your wireless adapters.
    and if you do the disable hard wire lan, make sure to shut down both computers and start 1 at a time.  wait untill the first one has a signal and then start the next.  sorry for the many comments, just trying to throw some ideas for you.
  • 10,515 Answers
Its simple.
Click the link and you would be able to read steps offered by Microsoft :-
http://support.microsoft.com/kb/306126
Thanks.
  • taran_2005
    taran_2005 Mar 07, 2009
    Make sure the firewall is allowing the networks.
    To be on a safe side for the time being, you may turn the firewall off on both computers if you have no idea to set the firewall for incoming and outgoing networks.
    Thanks.
  • 13,433 Answers
The router/ firewall is possibly blocking it. Whats the brand and model of your wireless router that both computers are connected to? whatkind of security your using also?
maybe we could look into this over remote support.
  • Ekse Mar 07, 2009
    I have to say Shadow1989 may be right about the Lan, Disable your lan connection., I've had that before but didn't remember.
  • 154 Answers
You make workstation both of the computers. and check again
I have AT&T DSL service with a Motorola 3347 modem. The wireless function was working just fine when I set it up yesterday, but now it's decided that I only get limited access (i.e. nothing) on the...
power down the modem . Check ADSL filters match the ADSL service eg ADSL 2 service has ADSL 2 filters.
Power on Modem wait 5 minutes for it to resync with DSL and see if internet is back up.
Aug 02, 2017 | Arris 3347 DSL 4-Port Wireless Modem -...
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I cant connect to two computers at the same time
How to connect....
1- Two Computers:
# We are connect two computers together to share Internet, printer, scanner, files, and even programs
We can do it through either way:
1- Use A Crossover Cable And Two Network Cards.Two network cards are installed in two computers.Then use crossover cable to connect them.
2- Use a Phone Line and Two Special Adapters Sold as "Phone line network Kit". Two adapters are installed in two computers. Then use existing Phone line to connect them.
Connecting Two Computers Wirelessly:
1- Wi-Fi
2- Bluetooth
3- Infrared
Several types of fixtures exist for home networking:
1- Hubs
2- Switches
3- Routers
2- Computer with the internet
Before you can connect to the Internet and access the World Wide Web, you need to have certain equipment. In brief, you must have:
-A computer (preferably running an up-to-date operating system); -
-A modem and access to a telephone line or a local area network (LAN) that is in turn connected to the Internet; and connection software that will allow you to establish an account with a service provider and access the Internet
You Need:
Modem: This converts your digital computer information into analogue telephone signals. Phone Line: his may be your biggest expense after the equipment.
Internet Service Provider (ISP): ISP has a permanent connection to the Internet.
ADSL: a newly standardized transmission technology facilitating simultaneous use of normal telephone services, data transmission of 6 Mbit/s in the downstream and Basic-rate Access (BRA).
ADSL facilitates the simultaneous use of normal telephone services, ISDN, and high speed data transmission.
Another advantage of having an ADSL line is not missing calls while you're online, as both voice and data can be transferred at the same time.
Jun 19, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Connecting wireless router to laptop computer
Please confirm that this model is indeed a wirlles Modem/ ADSL Router and not just a Wireless Router without the ADSL/ Modem capability??
Apr 20, 2008 | Linksys Wireless-G WRT54G Router
Wireless router
What is the make and model of your router?
What type of internet access do you have (DSL or cable)?
Are you connecting the computer with a cable or via wireless?
If you have verified that the cable connections are correct then I would try to power cycle next.
1. Unplug the modem, router and turn off the computer.
2. Plug the modem in and wait 5 minutes.
3. Plug the router back in.
4. Turn the computer back on.
Let me know the details for the above questions if we need to go further.
Dec 27, 2007 | 2wire Wireless-G 802.11g ADSL Gateway
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
