Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xd100 won't pick up the paper from the paper drawer
I use my xd100 as a copier -- not connected to a computer and never has been. I was using it tonight and it was working just fine. I changed the color of paper to copy on and it quit picking up the paper from the paper drawer. I've tried different colors and still the same problem. I have used different colors since we purchased it several years ago. I also tried cleaning the rollers with rubbing alcohol. Any ideas? Why was it working just fine and then not at all?
  • cschinck Mar 07, 2009
    Thanks for the offer of a solution but all I get is "see and a box with a red x" when I click on the box and then show picture nothing happens. Can you send again only in text? Thanks! Pam
    Clever!!! I had cleaned that part of the roller but I tried again using a Q-tip this time instead of just a paper towel. It worked for about 10 or so copies then didn't pick it up again. I opened and closed the drawer and it worked for a few more copies then, same thing again. I'm also getting a black line about 1/2 inch in from the side of the paper now. And, acutally, each time I cleaned the roller both with the paper towel and the Q-tip they didn't look very dirty. The copier sounds like it's running okay -- no gears slipping or anything. The rollers seem like they should have enough grip to them -- they don't seem smooth and still have grooves. Other ideas? Thanks for your help!! Pam
  • 101 Answers
Posted on Mar 07, 2009
Bottom drawer won't close and other drawer won't open
Sounds like the paper lifting plate for the bottom drawer hasn't lowered. The only way I know of to correct this is by removing the paper pick-up assembly. It's very easy. Open up the right lower door and you will see the paper pick-up assemblies. All you have to do is remove the two left screws. On the right side remove the cover. Then unplug the yellow wires under that same cover. Remove the single screw as well. The pick-up assembly should come out and the plate should drop. Make sure that the plate is free by lifting it and it should drop. This plate is not part of the paper pick-up assembly but is in the slot you've created by removing the assembly. If this is OK then replaced the paper pick-up assembly by reversing he procedure to remove it. As for the other drawer it may be a little harder. Possibly trying to loosening it and/or removing the paper assembly may help. It would be very difficult to help you without being there to see what is hanging the drawer up. This should help a little. Good Luck.
Apr 05, 2010 | Canon imageRUNNER 5000 Copier
Paper jams just as it comes out of the tray. It's
hi.have a look at your tray feed clutch.strip and cln
Nov 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I am using Toshiba e-studio 166. When i print say 10 documents together, at the output there are more than 15 papers i.e. 5 are unprinted plain papers come out stuck together in between. Please advise your...
Toshiba has extraordinary fingers and rubbers for paper pick up, so I assume that paper is the main problem.
Every time when you need to put paper in drawer you should shake a little bit (depends on paper manufacturer if they don't cut paper good they are connected with small tiny pieces of paper).
Also if paper is wet they will cause issues. Keep paper dry.
I hope it helps
Oct 31, 2009 | Toshiba e-Studio163 Copier
Xerox 7132 noise when picking up paper from bypass
there is either paper stuck around a roller (3) that feeds the paper or you have a bad clutch, most mnfs use magnetic clutches at the rear of the machine or bypass that get a red rusty dust in them causing squeal. recommend xerox takes a look...sorry they are quite expensive hourly
Aug 04, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper feeder not pulling paper from drawers, it does pul from the drawer but then when the second stage is supposed to pick up it does not and indicates a jam.
Have you replaced the paper pick up & paper feed & paper sep. rollers? If not try to clean the rollers with Wd-40 or simple green. If the copier works better, you will need to replace the rollers. Good Luck
May 17, 2009 | Canon CLC 1120 Color Copier
Xerox XD100 does not work
When you saying No working , What Happens when you press the print Button can you manually get this copier to print out ?
Has it stop printing only ?
Feb 19, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam or Will Not Feed
Sounds to me you have worn out feed tires.
Google a business called ' the parts drop. Give them a call.
They will have what you need, and at a fair price.
Jan 10, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
High pitch squeal, not picking up paper
it's not the gear..you are having a seized mechanism, most likely from something stuck in there.
Mar 13, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
121 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
