Question about Fisher Paykel EcoSmart GWL15
Fisher & Paykel Smart drive 9 Pride 5.5 Machine fills with water, doesn't agitate, then I have to turn off the power and then turn it back on to spin the water out
  • 351 Answers
SOURCE: fisher & paykel slow to fill?
if its the cold water (most common) replace the valve remove the two screws on the top of the control panel then you will see the valve i think its the right one looking from the front.its an easy job .hope this helps.
Posted on Mar 20, 2008
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
  • 1294 Answers
SOURCE: fisher paykel smart drive 9 pride
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your problem will be back for someone else to solve. Post back if not resolved, that is 'comment'
Posted on May 30, 2008
Spiz
SOURCE: Our Fisher and Paykel Pride
Sounds like your pump is blocked. **UNPLUG the machine**. lift or drag the machine to a spot where you can let the water dump out. The water comes out fast and makes a big mess. Tilt the machine back. On the front-right underside of the machine you will see the pump with the fan hanging down. Unplug the white plug and the earth cable from the back of the pump. You might notice that there is a white plastic clip that you can move to the side. Hold the clip out and twist the pump clockwise. At this point the pump will drop out and water will go everywhere. Try and take the pump out kinda fast so that the coil does not get too wet while the water is dropping out. you might find a blockage (coil, hair clip, underwire etc) sticking out from where the pump impeller sits. Pull out your blockage and check that the pump spins freely when you spin it by hand. If it does not spin freely you need a new pump.
Now, after you unblock your pump, you can put it back together the same way you took it off. Make sure the white plug is not wet before plugging it into the pump and make sure the pump coil is dry too! use a blowdryer to dry for a minute if unsure. When twisting the pump back in, the wires should be at the back of the machine and the earth cable is kinda close to the rotor (motor). Make sure the pump is sitting flat so the seal works too. That clip should click lock back into place to hold the pump from turning. The washer will not spin until all the water is out in case you are wondering. Hope this helps!
Posted on Aug 02, 2008
Scott Ellin
  • 558 Answers
SOURCE: I have a problem, I
Hi Norm33,
The often found cause of this problem is the door interlock. There is a safety feature to stop any operation while the door is open. If this becomes faulty, the washer may still not work even when the door is closed. Check that when closing the door, the catch is activating the switch. To test the switch, first make sure the WASHER IS NOT PLUGGED IN, then use an electrician's meter to test the resistance across the switch. You should put the two electrodes on the contacts at the back of the switch. When the door is closed, the resistance reading should read a very low value.
Another possible cause for this is a fault on the timer. You should inspect the connecting wires for any sign of burnt plastic or charring on the spade connectors. You will need to replace the timer if this is the problem. Please dont forget to rank me.
Regards
ELLIN
Posted on Sep 20, 2008
Cold water not pulling into Fisher & Paykel 5.5kg Smart Drive Pride.
Either the cold water inlet solenoid has failed or there is a fault with the electronic control module, Unfortunately the only way to find out is to replace the cold water solenoid and see if it works, if it doesn't then the electronic control board is faulty.
Mar 16, 2017 | Fisher Washing Machines
Fisher and Paykel Kelvinator Pride 5.5 Smart Drive 9 won't spin
There's something wrong with it. It sounds like its broken and needs to be fixed.
Nov 08, 2013 | Fisher and Paykel Washing Machines
Washing machine cuts out
The pump is over heating and cutting power.
Mar 30, 2012 | Fisher and Paykel Washing Machines
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel EcoSmart GWL15 Logo
2,069 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
