Question about Samsung RS2534 Side by Side Refrigerator
How to reset ice maker aFTER INSTALLING NEW SAMSUNF WATER FILTER
  • 700 Answers
YOU NEEED TO HOLD IN THE TWO BUTTONS AT THE BOTTOM OF THE DISPLAY ON THE FREEZER DOOR UNTILL THE FILTER INDICATOR IS RESET.
Posted on Mar 07, 2009
ICE MAKER NOT MAKING ICE..WHERE IS RESET BUTTON?
if no ice in tray check for a bad water refill solenoid. If water in tray check for bad heater that does not allow the scooper to push ice from tray into bin. OR
just get a new ice maker on the cheap from ebay
eBayeBay
Sep 22, 2017 | Refrigerators
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
70267990 Water will not run into the icemaker
Pretty simple fix. Your ice maker is it's own boss. It calls for water to be added after each harvest cycle. It and it alone. You have 4 things that could be wrong. Bad ice maker, bad water valve, bad water filter, and dirty condenser coils. The ice maker has a thermostat in it that calls for harvest. When that thermostat closes it powers up the motor and heater. Since the heater requires the most shocktricity to operate the motor will barely move. However as the ice melts the motor will gain ground until the main drive wheel rotates past a certain point and the heater is disengaged from the circuit, then the motor travels on around and dumps the ice. Near the very end of the harvest cycle a lever is tripped that powers the water valve for 7.5 seconds and fills the mold. Logically you want to replace the cheapest component of the 2 (ice maker and water valve) first just to see if that fixes it. You need a new watervalve anyway if you install a new ice maker. If installing a water valve don't do it (after you have cleaned the coils and know the water filter is ok and you have paid the water bill) then you would replace the ice maker itself. If the ice mold is full of ice and won't harvest you have a bad ice maker. Good rule of thumb: If you can add some water to an empty ice mold and it kicks out a batch then you need a new water valve. Ice Maker notes and service manual
Mar 23, 2011 | Refrigerators
Kenmore Elite model 59672286201. After installing new water filter, the ice is clumped together when it dumps, have to bust it with ice pick
you may have too much water coming in due to the extra flow from the new filter if you take off the front cover of the ice maker timer you should find an adjustment scew marked with a +/- reduce the cube size and the water should shut off sooner.
Mar 02, 2011 | Kenmore Refrigerators
No water to ice maker. Water dispenses in refrigerator ok. Filter is new. Also control panel not working in refrigerator section.
Its unusual that both parts would go at one time it could be you had a lightening strike or a power surge that took out both parts as they have nothing in common that one causes the other to operate other than temperature. This is what I would do. Since the control board is obviously bad I would replace that first. Let it run a day or two and if the ice maker does not start I would replace that part. I have linked them below.
To replace the ice maker module you must remove the ice maker and then remove the wiring before installing the new module to prevent the contacts from being bent inside the ice maker wire connector. Install the new module then connect the wires and place it in the freezer. Also if your ice maker has no water in it now the module is not the problem....get back to me.
Control Board
Ice maker Module
May 22, 2010 | Jenn-Air JFC2089HE French Door...
No ice or water, new filter was working when installed
check filter again. clean area before installing. check water. check to make shure power is on.
May 24, 2009 | GE Refrigerators
Purchased a water filter for my estate refrigator and the ice maker stop working.
when you replaced the filter did you check the flow before installing. I have had filters actually clogged right out of the package. Also most filters have a flow direction indicated with an arrow on the filter
Apr 15, 2009 | Refrigerators
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
Samsung RS2534 Side by Side Refrigerator Logo
288 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
