Question about Roper RAS8244KQ Top Load Washer
My washer is leaking water from underneath. How can I fix this problem
  • BColeman16 Mar 07, 2009
    My washing machine leaks underneath when its filling up inside the machine. The water turns off when it has reached the water level, but while the machine is in the wash cycle it is still leaking water underneath.
    Problem Solver:
  • 6 Answers
Are you sure its from underneath as a lot of washers seem to be leaking underneath but its actually a blockage in the soap dispenser. Or the water pressure is too high and splashing out of the dispenser in this case make sure the m/c is level front to back.
Posted on Mar 07, 2009
This is an Estate Whirlpool washer. It is leaking water from underneath? Check all hoses on back and they are dry(not leaking). Any suggestions?
could be 2 thigs the outer platic tub is broken or transmission or transmission seals are gone, go on line and see how to fix is very easy work on these machines.
Dec 27, 2015 | Estate Washing Machines
Leaking Washer
There is a pump underneath the machine. The pump might be bad. Pretty easy fix. It was a top load washer.
Apr 05, 2014 | Maytag Neptune Washer
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Gld5860l00ss QuietPower2 water leak
did you fix it yet ? check water line fittings underneath if you can pull a bit out washer to watch underneath when running to see where and when in cycle it leaks don't touch any electrical connections safety first LOL. disconnect power wipe dry and then ren it through a quick wash or other cycle and see.
Jul 10, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Water leaking from underneath after washer drains
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaking waher
water can leak from the other valve while filling up if you dont have the hose on it,if you blank the valve off with a nut and tail with a coin and rubber washer in it that will fix your problem.hope this helps.
Mar 09, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Roper RAS8244KQ Top Load Washer Logo
416 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
