Question about Vizio L37 Television
Vizio L37 blue screen only, "no signal", then turns itself off
All of a sudden, when i turn on the 2 yr-old tv, all i get is a blue screen w/a "no signal" message, and the tv turns itself off after 5 seconds. Vizio customer service/tech support atrocious; gave me a factory-authorized repair service phone number that doesn't work.
  • 2 more comments
  • matt Mar 07, 2009
    What is a "connection ic"? are you suggesting i replace the main board, and if so, is it something a layperson can do?
  • matt Mar 07, 2009
    i checked all connections, unplugged and re-plugged everything, to no avail. i am connected only via the coax cable, no box. tv shuts itself off after 5 sec. input button on tv doesn't change anything.
  • matt Mar 07, 2009
    YOU ARE THE MAN!!! I held the input button down w/the tv off like you suggested, and it came on. Its fixed!!! Thank you so much!!!
  • Kelly Twiss
    Kelly Twiss Mar 22, 2014
    This just happened to us 3/2014 and it worked. THANK YOU!!!!
    Genius:
  • 1,550 Answers
Connect the signal source like cables
Then go into the Channel/Signal menu on your set and select signal source.
Then go to SCAN or auto program and SCAN in all channels.
If you still get the message no signal . Then you have a bad cable /ribbon connection inside . Change this cable .
You can get one from the link below
Cable for Vizio tv
It will cost you $35 for replacement . You can do this replacement if you have service manual with you .
Else you can take to near by service center to get it repaired .
Hope this helps .
Posted on Mar 07, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi.please check on the following link.
http://www.tivo.com/setupandsupport/technicalsupport/issueswithmydvr/I_See_a_Searching_for_Signal_Screen_or_a_Bl
ue_Screen_with_a_TiVo_Logo.html
check it out..
thank u..
  • 10,515 Answers
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Almost always a 'blue screen' is indicative of 'no signal' which means that the TV could not sense any incoming TV reception. Pls try to check:
  • cables and connectors at the back of the TV;
  • your cable subscription and cable provider connections;
  • try using another video source such as a DVD or even an old VCR;
  • if you are using a receiver box, check the connections;
  • alternately, you may want to try switching 'SOURCES' on the TV such as Tuner, Line 1, Line 2, AUX, Video 1 or others.
Pls post back any updates on developments.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Mar 07, 2009
    Try an external signal source such as a DVD, video cam, game console or an old VCR and set TV to Video Input. If problem persists, then it would be the video processor of the TV. On the otherhand, if there is video using another//external source, then the fault would be with the tuner block of the TV. This is of course if you have confirmed that the cable TV is working by checking with another TV.
    If you are considering a DIY (do-it-yourself), then this would require opening the TV, familiarity with electronic components & circuitry, use of a DVD/VOM and a soldering iron. It would be to your added advantage access/referencing a Service Manual or at the very least a schematic diagram. Should you be uncomfortable going this route, perhaps your best bet then would be to seek the services of an authorized service center or a qualified professional.
  • 154 Answers
There is some fault on the main board. fault is likely in the connection ic.
TV wont stay on
Try changing the INPUT by pressing the button on remote control. Try plugging something else into tv. Ex, dvd player. And try that input also.
Dec 15, 2012 | Vizio L37 Television
I have a Vizio L37. When I turn on the TV it works perfectly after about 3 minutes the screen goes to green (no picture). However I still have the sound.
My first guess would be your t-con board. The t-con board is the one that transfers teh picture from your signal board to your screen. My second guess would be the siganl board is bad.
You can get parts at www.interliquidparts.com
Nov 29, 2011 | Vizio L37 Television
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
My Vizio L37 keeps turning off!
change the main board will fix this problem
May 16, 2009 | Vizio L37 Television
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
VIZIO L37 HDTV
daewoo37in(dlt37g1) freeview will not store saying no signal but freeview will install on other equipment using same imput
Jul 08, 2008 | Televison & Video
RGB
Press input until tv apears again. Or go into menu , setup Video input and select av or tv what ever you use.
Dec 23, 2007 | Vizio L37 Television
Vizio L37
try to go to the menu,then find the words,blue on or off,turn it off,then you will see the changers.
Nov 10, 2007 | Vizio GV42L 42 in. LCD Television
Vizio L37
you probably changed the input mode.
Nov 10, 2007 | Vizio L37 Television
Vizio L37 Television Logo
170 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
