Question about Toshiba Satellite M50 Notebook
I turned the my toshiba M50 last night. the next morning i was trying to turn it on, but it was just a black screen. i can hear the sound that it actually turned on but the screen is just black and no any display. please help!
  • toshuser Mar 07, 2009
    i cant use my laptop because the screen is totally black out. the sound is audible that the laptop is actually turned on, as it usually sound before this happened, but there is no display on the screen. what should i do?
  • Toshiba Master
  • 32,281 Answers
If you see a dim image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 07, 2009
Why Toshiba Satellite A665 Laptop won't start?
Have you tried pressing space bar (maybe its in hibernation mode) ?
or try holding power button for a few seconds (10) then turn it back on.
as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite A665-S6088 16 Notebook...
I have a Toshiba Satellite A665-S6088. The last time I used it was last night and everything worked fine. It works with Windows 8.1, it has for a few months now, never had any problems until now. No...
Unplug the unit from ac power. Remove the battery. Wait a minute. Press and hold down the power button for 30 seconds. (Yes, I know, nothing will happen visible). Replace battery. Plug unit back in. Now try the power button and see if the unit resets. Sometimes this helps when all else fails especially with a computer which has "hung up" like yours. Let me know if this worked!
Aug 26, 2014 | Audio Players & Recorders
Toshiba A305-s6858 black screen
I have same problem with HP laptop, one of the things i did the first time was to take off the battery and press on/off button for twenty seconds, put the battery back and turn it on. That works for me and i hope to help you.
THX.
Apr 25, 2012 | Toshiba Satellite PSAG0U-02D00M Notebook
How do you fix a computer that has a black screen
When you turn on your laptop and the you see the Toshiba logo start tapping F8 and it will take you to Windows Advanced Options. Select Safemode with networking. Go to Toshiba's website and install video driver if not Do a system restore to a the day before it started happening.
Hope that helps.
Jul 20, 2010 | Toshiba Satellite A100-S8111TD Notebook
Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
M50 SCREEN TOTAL BLACKOUT
i think there may be inverter problem.
Mar 07, 2009 | Toshiba Satellite M50 Notebook
Toshiba 56hm66 New lamp worked last night, wont boot up again
You now have a defective lamp ballast board. It sometimes is the root cause of lamp failures in these sets. The problem here is that Toshiba does not sell the ballast board independently from the larger, more expensive light engine assy. Call Best Buy back and get a servicer out there. He may have to take the ballast board out of your TV and send it out for rebuilding.
michtech
Feb 12, 2009 | Toshiba 56HM66 56" Projection HDTV
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
No pic but sound :/
You are having a high voltage problem. Quite possibly in the horizontal deflection. I would check the horizontal output and regulator transistors.
Sep 27, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba Satellite M50 Notebook Logo
218 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
