Question about Tag Heuer New Aquaracer Alarm WAF111Z.BA0801 Watch for Men
Can't set alarm on new Tag Heuer Aquaracer
How do you set the alarm on the tag heuer aquaracer?  I've followed the instructions and it doesn't work.
4 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
  • 19 Answers
SOURCE: What type of swiss quartz movement is in a tag
ETA or F0 movements are usually tags number 1 choice of movements.
ETA G10.711
Posted on Jul 14, 2009
escapement
  • 2334 Answers
SOURCE: How to adjust the steel band on my Tag Heuer
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Tip
    TAG HEUER Aquaracer quartz chronograph manual.
    Follow this link and download original TAG HEUER Aquaracer quartz chronograph manual: http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1110.BA0804
    on Feb 09, 2010 | Watches
    Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
    If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
    Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
    Need an extra link for my Tag Heuer WAB1110.BA0800
    Look on eBay. Make your search with BA0800 this is the Tag Heuer band code. Hope this helps :)
    Jun 24, 2011 | Tag Heuer Aquaracer c wab1110.ba0800 Watch...
    I have a CAN1010 TAG AQUARACER CHRONOGRAPH and whe reset it the second arm doesn't reset to 0 but instead stops 2 seconds before..
    This works! Loosen the bezel all the way. Pressing the bottom button, press one time the topmbottom and see how the chrononhand corrects by one second towards zero. Do it again and have it reset. Tighten the bezel. Thats it
    May 13, 2011 | Tag Heuer Aquaracer Quartz Chronograph...
    I need an instruction manual for a Tag Heuer 50 Chronograph Aquaracer mens watch
    Tag Heuer recognizes manuals by watch caliber number, not the watch model. Browse through my Tips and Tricks. There are few Tag Heuer watch manuals. Check out if this can help you.
    Feb 24, 2011 | Watches
    I HAVE A TAG HEUER AQUARACER ELECTRIC WATCH (BATTERY OPERATED) THAT HAS AN ALARM FUNCTION THAT I CANNOT SHUT OFF. IT GOES OFF EVERY DAY. HOW CAN I STOP THIS?
    I presume you no longer have the instructions, so I explored the Tag web site and they do not appear to offer an option to download instructions for your watch.
    The only thing I can suggest is that you go to your nearest dealer and ask for help. You can find out where your nearest dealer is by going to the TAG web site "tagheuer.com". select one of the watches and on the right of the screen you will find a menu which includes "find your nearest retailer", who will be able to help.
    Jan 12, 2010 | Tag Heuer 2000 Aquaracer Chronograph...
    Need instruction booklet for Tag Heuer Classic Chronograph 2000
    PDF Manuals at Normal 0 0 1 2 14 1 1 17 11.1282 0 0 0 www.tagheuer.com
    Do a search for Tag Heurer manuals
    Mar 29, 2009 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    Tag Heuer New Aquaracer Alarm WAF111Z.BA0801 Watch for Men Logo
    236 people viewed this question
    Top Tag Heuer Watches Experts
    Jimmy Accardi
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
