Question about Samsung RS2630SH Side by Side Refrigerator
Fridge and freezer not working - lights are on
There is no fan or engine sound. not cooling at all. safety switch has been tripping for the last few days.
  • 700 Answers
YOU ARE GOING TO NEED TO INSTALL A THREE IN ONE BECAUSE YOUR STARET RELAY I KAPUT.
Posted on Mar 07, 2009
Samsung SR 61KTC fridge not cooling but freezer is fine fans seemed to be very noisy a few days ago now sound like not on at all
Had the same problem when the door switch broke. The electronics of the fridge thought the door was open and therefore the fridge would not cool. I noticed that the light wouldn't turn off when the door was closed to discover the switch was broken. It was an $11 part which my husband replaced and the fridge works fine now.
Mar 16, 2014 | Refrigerators
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
Have maytag fridge about 5yrs old and is triggering the safety switch to go off every 5-6hrs , the freezer is ok the fridge is not cooling, what is the problem
Most likely it is short cycling because the start components or condenser fan are defective. This causes the compressor to run for a few minutes and stop because of overheating. The overheating is tripping the breaker. The cycle will not change until the issue with compressor or fan is resolved. To continue to allow it to run like this risk permanent compressor failure. Thanks, Sea Breeze
Feb 20, 2010 | Refrigerators
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
LG Refrigerator has no cold air for fridge but freezer works fine
Sounds like the freezer fan(FF)is wearing out, This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. This repair costs parts and labor around $300.00
Jul 31, 2009 | LG Refrigerators
Refrigerator compressor not working
unplug the fridge,remove the electrical cover on the compressor to see if any wires are burnt off.you may have a defective start relay,wire off or compressor seized,that age not cost wise to replace compressor
Apr 09, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Fridge powers on but does not cool
Try pressing light blub switch whist doors are open as fan will only start when doorsclosed. If compreesor is running but not chilling it is either the compreesor has gone and wont be pumping or it has lost its refigerant. Hope this helps
Aug 23, 2007 | Frigidaire FRT18B4A Top Freezer...
Fridge is not cold but the light will turn on...
Try to uplug it for a few minutes then plug back in. Let us know if the compressor and fan kick on then otherwise we'll have to give more advice on where to look, etc.
Dec 24, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
156 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
