Wrong voltage voltage readings are Q15- .5, 126, 126 / Q16- .1, 122, 126 VDC +and-
  • e_norin Mar 07, 2009
    This Is for a NHT SUBTWO
  • 4,234 Answers
Since you don't list the make and model, I'm going to take a guess here. If you are measuring the pads of the output transistors, then the transistors are shorted and need to be replaced. Please post the make and model as well as what you measured so I can confirm the diagnosis and possibly provide any additional parts that should be checked.
Thanks,
Dan
Posted on Mar 07, 2009
Still need answer abouy my xantrex inverter showing fault reading fo2 n beeping
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
Mar 13, 2015 | Inverter Electronics - Others
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
SPEEDOMETER DIGITAL MILAGE READ OUT GOING ON AND OFF. BLINKERS WON'T CANCEL ON THERE OWN
The voltage regulator has failed if the voltage EVER rises above about 15.5 VDC. Surface voltage should not be as high as 13 VDC unless maybe the bike has JUST been shut off and then it should bleed down into the high 12's after about an hour of sitting.
The signal self cancellation is tied to the speedometer and the TSM/TSSM and so if one fails it will affect the other as far as signal self cancellation is concerned.
Aug 24, 2012 | 2003 Harley Davidson FXD Dyna Super Glide
Motor tripping out power supply
The input to your treadmill is about 120 volts Ac. The output from the board will be about 30 Ac. Almost nothing on there will be measured in DC. Your particular issue is your motor controller. It needs to be replaced.
Jul 27, 2017 | Reebok treadmill i-run s
Error 7
Incline calibration is necessary when: the display shows ERR7, the drive board incline error LED ( LED5) lights or the incline has extended beyond its normal rangeThe goal of calibration is to synchronize the incline set mechanically and electronically. Mechanical calibration sets the incline motor pipe to the 0% position. This happens when the red line on the thin pipe is even with the end of the thick pipe. Electronic calibration sets the variable resistor (VR) value to the 0% position. This happens when the voltage across the VR blue and green wires is 1.20 VDC.
Readings of VR voltage (blue and green wires) should show around 1.20 VDC at the lowest position and around 3.80 VDC at the highest position. If the VR looses calibration or cannot be set to 1.20 VDC, replace the VR. If the incline motor gets voltage from the drive board but fails to operate, replace the incline motor set. If the incline fuse blows again and again, replace the incline motor set.
Jan 19, 2012 | Sportsart 6300 Treadmill
The starter wont turn over. car will not start
please take a volt reading at the battery it should read over 12.5 vdc then take reading with the key in the crank piossion . the voltage should drop to around 11.0 vdc if not then you mave a starter relay or solenoid problem if it dorps below 9.6 then you have a barrery problem .please leave posative feedback. thanks
Apr 16, 2011 | Toyota Supra Cars & Trucks
Harley sportster 2001 starter removal ,it just clicks
You must have a fully charged battery.If you are just getting a click your battery proably doesn't have enough voltage to energize the starter relay.Check the battery voltage and if that is good 12.6 volts or more do a voltage drop test to the switch circuit( battery pos. to relay terminal 86) with switch on and starter button pushed the meter should read 1.0 vdc max if that is good black meter lead to relay terminal of solenoid again read voltage then engergize the system with only 1.0 vdc drop good luck
May 08, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Rear a/c blower won't come on.
you need a new blower motor resistor
Aug 29, 2009 | 2004 Chevrolet Suburban
Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
71 people viewed this question
 Grubhead
Grubhead
