Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
How to overclock a pentume 4 processor - Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
  • Micha Dozier May 11, 2010
    depends on what mother board you are using.
    Scholar:
  • 93 Answers
When starting/rebooting your pc, repeatedly press the delete key to open the BIOS, if the delete key does nothing (you can tell if does nothing it you see you windows xp/vista boot screen), reboot again and try to see if it says anything about settings/bios/configuration keys, press the mentioned key to get into bios settings.
Once in Bios settings you can overclock your CPU, since BIOS configuration layouts differ, just look around and make sure you don't change anything (it usually says what keys do what on the bottom).
IMPORTANT NOTE: overclocking a processor may, and most likely will cause damage (due to excessive heat) to your CPU as it was not built to work at higher frequencies/speeds. If you have only a normal fan for your cpu, or no fan at all, get liquid cooling or a specialized fan and heatsink for overclock to minimize or even possible eliminate damage that can be done. The damage or effects of the damage will not be 'seen' or known
If you are not happy with the speed of how your programs start up, I suggest you get more ram instead. Increase in Processor speed is more for multiple programs running, and them being slow while your are using them regularly. Also another reason for an need for a faster processor is for games/video/3d editing. If you do neither of those, don't try overclocking.
Posted on Mar 07, 2009
  • Denis K. Mar 07, 2009
    Like the others said, it might not work with your motherboard, but check your bios settings/config to see if it is possible.
  • 101 Answers
Increasing of FSB (processor clock) from 10% up to 15%.
from 1700Mhz you can get 1850 Mhz.
from 2400 Mhz you can get 2640 Mhz
from 3000 Mhz you can get 3300 Mhz
but not all mater board allow this do.
IBM 8123 K1A powers on but no display
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 03, 2013 | Computers & Internet
Is pentum(R) is pentum4
No, Pentium is a line of processors that has started in 1993 and has had no less than 83 versions up to date. On your motherboard goes a Pentium 4 socket 478 core Northwood processor.
May 26, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
How to overclock foxconn g41mxe motherboard with intel core 2 duo e8500 processor up to 4 ghz
I doubt very much you will get much response to overclocking here incase you do damage try www.overclockers.com
Feb 23, 2010 | Computers & Internet
Problem in overclocking my Processor.
1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
Mar 30, 2009 | Intel Computers & Internet
Overclocking
are you sure that your pc is built for overclocking? dont be risky it might get you trouble on your pc. i suggest that you shouldnt overclocking it and besides your processor is high ed.
CHARCOIS
Aug 24, 2008 | Intel (P42000400256SK478) Pentium 4, 2 GHz...
Overlocked my Intel Pentium 4 3.00 Ghz
You have to go into your bios and see what your front side bus and memmory speeds are. If you overclock you cpu, sometimes you need to underclock your memmory. Say step your memmory down to 333mhz and overclock your front side bus(fsb).
Normally your fsb is 200 and only increase it by mhz. Restart, go into windows. and see if it is stable.
I always use cpu-z and gpu-z to check all of my hardware settings. I use ati tool to overclock my x1950 and it is great. There really isnt any good cpu overclocking tools because its better to do it in the bios.
Do a specific search in google for your processor and overclocking.
Jun 06, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
CPU RATIO?
Of course is has to do, almost everything has to do with overclocking, but what is that you need to know really? ... and personally I strongly recommend NOT TO OVERCLOCK.
Mar 09, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Overclocking
overclocking is a risky processor which increases cpu speed . i causes cpu burn out causing damage to mother board . if ur computer is in warranty time then ur warrnty might be get cancelled and can cause serious money loss
Dec 23, 2007 | Computers & Internet
OVERCLOCKING
The 800 MHz seems to be your system bus speed and not the CPU speed. They a related but no quite the same. Overclocking is usually defined as forcing something to operate at a higher speed than it was designed to. If you changed the 800 MHz to 1.6 GHz in your BIOS then yes it could be considered overclocking.
One thing I would like to mention is that when changing clock speeds in your BIOS, do it in small steps, if done in large steps it can cause system instability.
Oct 28, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
How can I overclock my 166mhz classic computer?
Overclocking is not really recommended to be done by normal users. For overclocking your computer, you should have extensive knowledge of the hardware of your computer.
Overclocking may result in a totally non-working computer, burnt up Processor and motherboard and the likes. Also, overclocking results in heating problems, so you need to have made the arrangements for taking care of this heat issue.
Basically overclocking means increasing the Clock Speed of your comuter. Suppose I say that I have a Pentium 4 - 2.4GHz computer, the 2.4GHz part is the clock speed, which is increase in overclocking. Surely the computers with higher clock speeds work faster but that comes at a price. A small mistake on your part and your computer is no more working.
There are various Forums and sites on the internet that discuss Overclocking and its intricacies in greater detail.
Here's a pointer:
http://www.extremeoverclocking.com/
PS: Search google for "overclocking" and you should get a lotta links to work with.
Oct 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
159 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
