Question about ViewSonic Office Equipment & Supplies
New ViewSonic PJ 513DB connected to laptop. Cannot see DVD
When connected to my laptop, It projects the laptop screen and al the programs just fine but if I try to watch a DVD in my laptop only the commands from Real Player or Window Media Player are projected, no picture.
Any helpful input?Thanks
I think this is your laptops problem with putting out that on both displays at the same time try cloning or playing with those settings
Posted on Mar 10, 2009
Green and yellow color with viewsonic pj551 projector
the LCD panels are failing
the price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Feb 11, 2014 | ViewSonic PJ-551 Home Theater Projector:...
I'm using an acer aspire laptop and a viewsonic projector. projector colors and disply works fine with an xbox bt when i se my laptop, the projector screen goes red. is it the settings on the comp
Make sure you have all drivers and software necessary for the projector installed on your laptop. You can find them on viewsonic's website. Also go to Control Panel>Display>Connect to a Projector and insure all settings are correct. Let me know if you run into problems.
Jun 13, 2012 | Acer Aspire 5100 (5100-5674) PC Notebook
It worked beautifully last night with my macbook in a test run of my powerpoint, but this morning I plugged it in for the REAL presentation it didnt work. A bright, clear picture of the Viewsonic Logo...
you might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
Mar 23, 2017 | ViewSonic PJ458D DLP Projector Multimedia...
My Viewsonic PJ 500 projecter light is not turning on. "lamp" light is blinking.
That means that the bulb is bad and beeds to be replace, This usually happens after 1000 hours of use.
Aug 28, 2010 | ViewSonic PJ500 Multimedia Projector
I can not connect a Viewsonic PJ260D project to Hp2140
Interestingly enough i simply rebooted and it workrd..... 4 hours of frustration solved by a simple task...
Jun 12, 2009 | HP 2140 Netbook
Viewsonic Projector PJ557D "Screen Flip"
Check the power settings o nthe laptop, go to control panel, power options. see if its set to turn off the screen if theres no activity. I doubt this is your problem but worth a try. Going back to the viewsonic picture means its not getting a signal. So either the cable may be faulty which is less likely, or it is a software problem. Does the screen flicker on the laptop when doing the same thing (if the projector is not connected)?
Jun 12, 2009 | ViewSonic Lenovo Viewsonic PJ557D Portable...
Dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
Mar 04, 2009 | ViewSonic PJ501 Multimedia Projector
Epson powerlite 7700p video problems
could be, colour change is typical of a pj lamp expiring.
check first the connection lead between pc and pj
to make sure pj is seeing all signal pins on sub d lead.
check pj with video sig input, if thisis ok it's not the lamp failing
Feb 20, 2008 | Office Equipment & Supplies
Sanyo plv z4
look in the projector menu ( should not be backwards) and switch the view to front projection. It might be set in rear projection. That is what my viewsonic PJ-558 projector can do sometimes
Jan 26, 2008 | Sanyo PLV-Z4 Multimedia Projectors
245 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
