Question about EliteGroup P4VXASD2 Motherboard
P4vxasd2+ motherboard what kind and size jumper caps do i need to change over to ddr memory, i think you need to short out all the pins that run along one side of the motherboard,, the ones i bought do not fit?? even though they are the same size as the other jumper caps on the board, any help would be welcome,, thanks.
  • Anonymous Mar 07, 2009
    there is a row of jumper pins that need to be shorted for the ddr to work, i need to know what size jumper caps will fit on these pins, they do not tell you in the manual..does anybody know ??
    thanks
The other guy who responded isn't familiar with this motherboard. You need really small jumpers. I found them at Fry's.
Posted on Dec 18, 2009
    Problem Solver:
  • 18 Answers
This option should not need to be enabled through jumpers, the bios should automatically detect the ram type on the motherboard, make sure you are using compatible memory.
Posted on Mar 07, 2009
Does 1rx8 ram go along with 2rx8?
Look at your motherboard manual, it tells you what kind of memory, which slots to use for number of sticks.
Your statement makes no sense, 1r, what is this ?
There is speed and size of memory.
DDR-, DDR 2 or DDR3, then speed, DDR3 2000 which each speed has a corresponding number.
DDR3 2000 is called ( PC3 16000 )
The chipset of the motherboard dictates what size and speed of memory that it can use.
Dec 05, 2012 | Biostar Computers & Internet
Ddr jumper settings M925g 9.1b?
Hi Ronald.
Not completely sure but I think this is the manual for your motherboard.
You can download it here
Also not sure if it's complete, it seems to stop short, but that may be just me. It should open with Adobe Reader.
Jan 31, 2012 | Computers & Internet
Hi! How to remove bios password from Toshiba Satellite A500?
I got a bios protected Toshiba A500 PSAR9A from auction. Solved by the method below:
1. Open ram cover and remove all rams
2. Tear off the sticker on motherboard.
3. you will find 2 jumpers there, J2 and JCOMS.
4. Use some kinds of metal wires to short connect JCOMS, use some tape to stick it, make sure the metal wire under the tape is exactly short the jumper.
5. Put the ram back and turn on the laptop
6. The ps should be removed, then take the metal wire off.
Don't know if all steps needed because have no chance to try again. But this method is exactly works.
Feb 27, 2011 | Computers & Internet
What kind of memfory do I need for a P4M80-M4 Motherboard? I want to install another card.
Here is the specs of the memory that you can use for this motherboard.
2 x 184-pin DDR SDRAM
PC3200 (DDR400) DDR SDRAM
Maximum 2GB
Jan 03, 2011 | Biostar P4M80-M4 Motherboard
P4VXASD-R VIA Apollo P4X266-new 1G DDR gets 3 beeps
Well you said you used 256+128 and thats lower than 1gb. So try sticking in one of the stick and run it, see how it is. Then try the other, if both are working fine by themself then try cleaning your board with a nonscrathing cloth (or q-tip).
Lastly, just double check if your motherboard runs that kingston type, the pc2100.
As for your memory goes, os 2k can run up to 4gb of ram.
Jun 11, 2009 | EliteGroup ECS P4VXASD2 VIA P4X266A...
Installed new memory. will not restart, rear
That could be a couple of different issues.
  • Memory may not be seated all the way. It should "snap" into place.
  • Make sure it's right kind of memory. The Dell Dimension 3000 takes 333MHz DDR SDRAM. Look on the chips to see if it says 333 or PC3200 anywhere.
  • The max memory for that machine is 1GB, so my guess is each memory card is probably 512MB max. Larger ones may not work
  • It's possible the memory is bad, replace it as last resort if nothing else fixes it.
Let me know if none of the above works.
Apr 07, 2009 | Dell Dimension 3000 PC Desktop
Need to know jumpers for adding 2gb ddr ram if there are any
You have inserted RAM in the worng slots. Insert it in alternate slots and not in adjacent slots.
Mar 24, 2009 | EliteGroup P4VXASD2 Motherboard
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
Upgrading processor
i think that the FSB needs to be set at 133 as this relates to your memory timing and im guessing your ram will be sdram, apologies if it's ddr, but you will find that you can up the cpu speed within the bios, in small increments. Don't forget the speed of athlon processors does not match the model number, the 2400 means it will be the equivelant of a pentium 2.4 GHZ, but it will probably show a GHZ rating of 2 or 2.2 Also try reseting the cmos by shorting a clrcmos2, clrcmos,clrrtc or putting the jumper from pins 1-2 to pins 2-3 then back again if it's a JBAT1 terminal, depending on your board.
Jun 13, 2007 | Asrock K7S41GX Motherboard
Missing part
Hi, Sorry to tell you but this motherboard supports ONLY SDRAM memory. There is no way that a DDR memory will fit into this motherboard. What you can do is add another SDRAM memory for better performance.
Apr 28, 2007 | Syntax SV266A SKA KT266A Motherboard
EliteGroup P4VXASD2 Motherboard Logo
627 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
