Question about Bang and Olufsen Beosound 2000 Shelf System
I have a Beomaster 5000 amp which starts up then after about 10 seconds shuts down
  • akempster Mar 08, 2009
    I am unable to locate the fuses, and do not have a manual or wiring diagram?
    Genius:
  • 1,550 Answers
It sounds like it had a power surge.
Initially check the fuses .
Posted on Mar 08, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Please check for any blown fuses or burnt wiring.
  • Rylee Smith
    Rylee Smith Mar 08, 2009
    If you are using a any of these with it then check---
    Turntable - check for cartridges
    Tape deck - Belts both for the mechanism and the loading drawer, but these are readily available.Also, a 10 Ohm resistor in the power supply that is under-rated power wise and eventually burns out.
    CD player - if it stops reading discs, everyone assumes the laser has failed. 95% of the time they are wrong - the spindle motor lubricant dries up and means that the unit can't quite spin the disc fast enough to read it. Motor can be stripped and rebuilt but it's a nasty job and requires careful alignment when reassembling.
    Receiver - no problems known other than a propensity for the microprocessor to blow up if the unit suffers a lightning strike.
    After its been off for half an hour or so, check the output DC offset on each channel, which should be 11mV - this can drift with age
    Also see this link for Beomaster internal connections---
    Beomaster 5000 Amp internal connections
    Please ask for further clarifications.
    Thanks
    Rylee
  • Rylee Smith
    Also, check for a ribbon cable, you need to dismount the display and flip-down the front panel to gain access to the cable.
    And instead of them try using the discrete/single wires for connection.
    Make sure they don't get into a squeeze against the lower front frame chassis when closing the panel and take a note of the position and exact path of the string for the front panel dampener before taking it apart.
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Gateway laptop stayed on blue screen and it says intalling updates but hasnt moved from 1 of 159
The only thing that you can do at this point is Shut it down. If this is windows 10 it will recover by itself when it powers back on. To shut it down you can hold the power button down for 10 seconds.
Sep 28, 2015 | Gateway NE52204u Silver 15.6" Notebook 1.5...
I have a beomaster 5000 which will cut out at any time sometimes it goes for ages,other times it will go almost immidiately,also i have the beogram 5000 and the cueing function doesn't seem to raise the...
O.k. The Beomaster 5000 needs new Quiescent current presets , you can temporarily solve the problem by turning the two presets (in the main amplifiers) fully anti - clockwise .
Your beocord needs new belts for sure .. availiable from CPC of Preston .. Hope this helps ..
Oct 29, 2010 | Bang and Olufsen Beosound 2000 Shelf...
I bought a used coleman powermate 5000 generator, I replaced the spark plug and fuel filter, it finally started up,it would only run in the "choke" position it ran about 10 minutes and then shut down, I...
What brand of engine & horsepower is it?Also about how long was it stored or last time it was run? The reason I ask is if it was stored with gas in it & a fuel stabilizer wasn't added to it,your primary jet is plugged in the carburetor(reason it will only run while choked).
Jan 07, 2010 | Coleman Powermate Powermate 5000W...
Beomaster 5000 no sound out of left side
there is probably an internal fault but check that the pre out main in links are both there and the sockets to them are properly soldered.
Feb 16, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Sound distortion on beomaster 3300
There is a defect in the pre-amp section of the unit. Without seeing it and taking a few measurements, I can't give you any particulars. A rough estimate for a repair wouldbe about $10-$25 in parts plus the local labor rate.
Dan
Sep 30, 2008 | Audio Players & Recorders
622 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
