Question about Maytag MAV7600 Top Load Washer
How to replace the belt on an AMANA LWD70AW washing machine?
The original belt was cracked in multiple places and broke/melted at the motor pulley. I have the replacement belt, but I do not the instruction sheet or a schematic of how to replace the belt. It looks like you need to remove the pump screws (3) with a star bit or allen wrench, but not sure what size or what socket assemby to use. The motor runs and the tub pulley rotates but the tub must be locked at the end of a cycle. Any drawings or assistance will be greatly appreciated. I hope someone is up tonight to help me with this problem. Thanks for listening and I look forward to hearing your solutions.
All the best, Tom
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
SOURCE: Maytag Washer PAV2300AWW
Your Thrust bearing on the bottom of the transmission is not releaseing the break. try turning the pulley with the belt off in the opposite direction this should free up your break. If it doesn't replace your brake ststor and rotor as well as your thrust bearing. This should solve your problem. Roger
Posted on Sep 27, 2007
  • 15 Answers
SOURCE: Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
Posted on Oct 10, 2007
the dr
  • 447 Answers
SOURCE: replacing belt on Amana LWD70AW top load washing machine
There is a post for this in my solved solutions. If you cant find it......amasuperbike@comcast.net
Posted on Jan 10, 2008
vest6
  • 196 Answers
SOURCE: Amana LWD70AW
Check the belt idler wheel by the motor. You may have to apply a little pressure to this wheel to see if the belt stops slipping. Keep in mind that the belt may be worn or stretched
Posted on Jan 13, 2008
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
Belt removal for Amana washer model#LWD70AW
u have to wiggle pump from side to side and up and down shoul losen up and pull strsight out
Apr 11, 2009 | Amana ALW480DA Top Load Washer
Amana dlw330 washer belt urned & broke again
Had the same problem on a machine I worked on. Changed the belt... was burnt and broken. Second time I replaced the belt, I ran it through all of the cycles and listened to it on SPIN cycle.. Although it's spinning.. it's making an extremely LOUD noise... It's the Spin bearing that is gone out. When a load is put in, and in spin cycle, the bearing is oveloaded..(being dry).. and putting extreme pressure on the motor and belt. When the drum reaches a point where the bearing just won't spin, the belt stops, and spins on the motor pulley, wearing it through.. (And smoking a great deal).. until it breaks.. again. I believe the top "Spin bearing" is about 75.00 or so.. and a BEAR to replace. Hope this helps
Feb 26, 2009 | Amana DLW330RA Top Load Washer
Amana dlw330 washer belt burned & broke again after I replaced it
well if hte washer belt is "burning off"" that tells me the motor is trying to spin at full speed buthte transmision pulley is holding it back, can be a few issues, either the brake is notreleasing correctly or, the transmission is locking up .
Feb 26, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
The belt broke on the washing machine
You will have to remove the whole motor assembly out, then remove the water pump using torx 20 from the whole motor
Dec 14, 2008 | Amana ALW480DA Top Load Washer
Amana lw8252w2 changing belt
there are 3 screws that hold the pump to the moter but sometimes it is rusted so you may need to pri it off
Nov 29, 2008 | Amana ALW480DA Top Load Washer
Replacing belt on Amana LWD70AW top load washing machine
Jan 10, 2008 | Kenmore 24032\24036 Top Load Washer
How to remove pulley from pump?
Your question suggests you are trying to remove the pump pulley. This pulley is not removable. The motor pulley should have a set allen screw in it to release.
Sep 26, 2007 | Amana ALW480DA Top Load Washer
Changing belt on washing machine, that broke
to change the belt you need to remove the pump attatched to the motor. the pump is held on by either spring clamps or in older models, torx (star) screws. I believe the size for the torx screws is #20. slip the belt over the motor pulley and around the tension pulley and finally around the transmission. reinstall the pump and you're good to go.
Aug 18, 2007 | Amana ALW540RA Top Load Washer
Maytag MAV7600 Top Load Washer Logo
107 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
