Question about Microsoft Computers & Internet
We are using the 16GB Compact falsh within that we are using windows Embeded XP(Its Licienced Version) ,But after login to the System. The Following Message is Coming. The instraction at ''0x71ab664d'' refrenced memory at ''0x71ab664d'' , The memory could not be ''read'' This Message Coming inside Dialog Explorer.EXE - Application Error.
    Problem Solver:
  • 18 Answers
Sounds like a memory corruption problem. Is the memory card rated at a fast enough speed for the application you are intending to use it for?
I would try to reformat the memory card and try again. If that fails, it is either a faulty memory card or the card isn't rated for that type of use.
Posted on Mar 07, 2009
What should i download to get 32bit operating system software
What is the difference between 32-bit and 64-bit versions of Windows?
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information.
The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. How can I tell if my computer is running a 32-bit or a 64-bit version of Windows?
To find out if your computer is running a 32-bit or 64-bit version of Windows in Windows 7 or Windows Vista, do the following:
1. Open System by clicking the Start button , right-clicking Computer, and then clicking Properties.
2. Under System, you can view the system type.
If your computer is running Windows XP, do the following:
1. Click Start.
2. Right-click My Computer, and then click Properties.
If you don't see "x64 Edition" listed, then you're running the 32-bit version of Windows XP.
If "x64 Edition" is listed under System, you're running the 64-bit version of Windows XP.
Download it here:
https://www.microsoft.com/en-in/software-download/windows8
Mar 29, 2017 | Computers & Internet
NEED TO GET BY THE WINDOWS XP PASSWORD I FORGOT
If this is a power-on password you need to get around, try the following:
1. Power down your system.
2. Power on the system.
3. Tap F8 as the system powers on.
4. Choose "Start Windows in Safe Mode with Networking" (or any "Start Windows in safe-mode" option. Networking just gives you internet support).
5. When the windows login screen appears, you may have another account available called Administrator.
6. Click on the Administrator account.
7. When the desktop comes up, go to START > Control panel > Users and Accounts
8. You should be able to find your normal account you login into.
9. Depending on the settings, you may be able to view information within the Users and Accounts control panel. I believe there is a way to view passwords, or remove passwords from accounts from within the Administrator level Users and Accounts control panel.
10. Locate your account and view the settings. You should be able to remove or view your password. (Circumstance varies in this regard, as the results depend on whether the administrator level of the control panel has been restricted or the options modified in any way previously).
11. When you are finished, power down the system normally.
If there is no Administrator account when the windows login screen appears after starting in safe mode, this feature is disabled and you can not access the administrator account from a safe-mode start-up.
Jan 10, 2011 | Computers & Internet
When I login into my Windows XP System I get the following Pop up : "Windows Cannot find C:\WINDOWS\system32\drivers\Prgds.exe'. Make sure you typed the name correctly, and try again. To search...
It is a virus, run a full scan using your anti-virus software. Also, go to run and type regedit and look for prgds.exe under startup. If it is there, uncheck it. In addition to that go to malwarebytes.com, download the free version and run that.
Dec 23, 2010 | Computers & Internet
Xp installation problem
the system doesn't accepts the lower version of windows if you are having the latest version than xp. for thi you must format the two OS softwares and first install lower version i.e., xp and then by dual booting you can also install vista or windows 7. then you can use both versions..
May 29, 2010 | Gateway T-6330U Notebook
How do I add drivers to windows XP embeded after
Install the Drivers from the Motherboard CD by double clicking the Video Card Drivers Setup.exe file, follow the steps and the drivers are installed.
Oct 15, 2009 | Computers & Internet
Install Win XP SP 2
Yes you can, Do I recomend it, no, Why?
Windows easily uses up to 756MB of RAM to run the O/S alone but can run at a minimum of 512MB.
I have personally seen it run on as low as a 900Mhz processor, 256MB of RAM and on a 10 gig hard drive.
If you decide to install windows XP on the specs you describe above please note the following.
1. System will be very slow and have lengthy start up times.
2. Applications may crash or take a long time to open.
3. With all the updates for WinXP you will easily use 8 gigs for installing XP and its updates. Not to mention whatever software you will use/install.
4. On a system with those low specs, you probably have a low end video card whcih may result in: A. chooppy windows, screen freezing, system crashes and lock ups, low video graphics all around.
I would probably go with windows 2000 instead. If your bent on having XP, at least upgrade the RAM to as much as possible. Then install windows and only install the programs you really need, remove any other junk.
Hope this is of some help to you, good luck
Feb 17, 2009 | Dell Inspiron 4000 Notebook
Will not boot to XP
these are some following procedure
do it carefully
XP Repair install Please read carefully and make sure you followed the warning links before initiating the Repair Install. You can print a text version for reference. repair.txt
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" width="15" height="21" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. If you get files not found during the copying stage.
    Blaster worm warning: Do not immediately activate over the internet when asked, enable the XP firewall before connecting to the internet. You can activate after the firewall is enabled. Control Panel - Network Connections. Right click the connection you use, Properties and there is a check box on the Advanced page.
    KB 833330u Blaster removal
    What You Should Know About the Sasser Worm and Its Variants
    Microsoft Security Bulletin MS04-011
  7. Reapply updates or service packs applied since initial Windows XP installation. Please note that a Repair Install using an Original pre service pack 1 or 2 XP CD used as the install media will remove SP1/SP2 respectively and service packs plus updates issued after the service packs will need to be reapplied.
Oct 13, 2008 | Microsoft Windows XP Professional for PC
CADKEY 97
I had a similar problem trying to run under Windows XP and 2000 Pro.
I deleted the file named opengl32.dll from the Cadkey directory and now everything works fine.
By the way, Cadkey would load up and it seemed to be OK until I needed to type anything in, then it would make a warning sound and ignored the key strokes.
I hope this helps and works for you.
May 12, 2008 | Cadkey Corp CADKEY Version 6
Computers & Internet Logo
106 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
