Question about Samsung CLP 300 Laser Printer
Smasung clp 300 will not print in blk
My samsung clp 300 printer will print well in color however, black is very light almost unraedable have change toners and even cleaned.
  • 2 more comments
  • samsung642 Mar 09, 2009
    Tried OEM and now compatible. Black and grey is really bad. Never seen so bad printouts with laser before.
  • layninat Mar 19, 2009
    Half side of my paper when use balck comes out very light. I hav had to change my font to colour just so can print invoices. Toner is new, just happened all of a sudden.
  • sesquiplicar Mar 28, 2009
    Same problem- black print virtually illegible. Tried everything, to no avail.This printer has been a problem since day one- engineers had to replace imager wihtin 6 months, but now of course it's out of guarantee. Going back to cheap and cheerful inkjet
  • trman Apr 02, 2009
    Exactly the same problem - the black ink is faint on the left half of my page. It also happened very suddenly and may have occurred after I printed a 20-page document. The is the second CLP-300 that has done this.
check if your toner cartridge(s) is moving the toner supply spiral,
you can see it in hole where toner leaving bottle. (you must push the
valve in cylindrical output of cartridge inside about 20mm).
When you rotate anti-clockwise gear of cartridge, the spiral inside must rotate too.
My original toner has this broken and print was light.
You can have also bad developer unit, blade, or contacts, or printer electronic board.
Posted on Mar 07, 2009
I also have the same problem, I have tried using THREE different black cartridges. I have tried messining around with the cylinder and cleaning the rollers ect. All to no avail. I now have to convert text documents to navy blue in order to print out a readable copy.
Posted on Mar 10, 2009
Samsung CLP-300: Black print is fading replaced black cartridge twice all the other colors print fine
Dear,
This is a problem with a black developer. in the imaging unit. Kindly approach authorised service center. they will change for you.
Sep 27, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Printer
smasung clp300
just clean toner weast chember and also drum unit.
sometime if u user refilled cartridges after use this u have facing this porblme.
pl do this it work perfect.
www.howtorefill.com
Jun 02, 2010 | Samsung CLP 300 Laser Printer
My Samsung clp 510 printer won't print in color. How can I fix it??? I just installed a new black ink toner cartridge and now it's not letting me print in color. About a month ago I replaced the color...
I had a similar issue with my 510. My printer would only print in b&w regardless of my settings in the printer setup. I uninstalled my printer driver and reinstalled a fresh one from disk. This cleared up my issue.
Mar 26, 2010 | Samsung CLP-510 Laser Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
POOR PRINT QUALITY WHEN PRINTING IN BLACK ONLY
may be your new toner can be faulty.you can try this processor first you remove the toner & refix it after shaking.if your problem is not solved then check with new toner again.
Sep 02, 2009 | Samsung CLP 300 Laser Printer
Black color doesnot print at the middle of the page
The problem is that the black developer has a defect. You cant't solve this problem by your own, you have to call the service. The service tecnician change the developer and make a FW Update.
Greetings from Germany
May 21, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP 300 is printing black text light
I have the same problem. Blk toner is new but its really light down the middle of the page. Can't hardly read the text.
Feb 01, 2009 | Samsung CLP 300 Laser Printer
Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
Jan 05, 2009 | Samsung CLP 300 Laser Printer
Can't print just black when out of color with Samsung CLP-300
its not possible till you get that rec colour refilled in your colour cartridge or replace the colour cartridge.so you cannot print black as the printer is not been able to end its cycle as the cycle is getting break at the colour cartridge.its very common problem faced by many users but no other option except replacing or refilling the cartridge.
thanks.
Dec 14, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
662 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
