Question about ASUS P4R800VM MOTHERBOARD P4/SOCKET478/MATX/4GB DDR/400MHZ/FSB (MTHP4R800V)
Asus mobo totally dead, no post, no beep, no power switch. help me please..
  • Joe Budd Mar 07, 2009
    Thanks for support,
    Fortunally i was check all power consumption it all good beside that little LED in mobo light normally but still I can switch on.
    Cmos and battery has been removed and cleared.
    Any suggestion?
  • 52 Answers
Have you checked the power supply to make sure it is turned on, if so then proceed to the power cable and make sure it is plugged in to the back of the computer and the wall socket, if everthing checks out there take the side panel off of your computer and check to see if there are any little lights on the mobo if so then you know the mobo has power if it functioning properly the next step would be to replace the mobo with a new motherboard.
Posted on Mar 07, 2009
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Video adaptor giving beep code on post Asus M/B M2NPV-VM 1 long then 2 short beeps also has a usb over current issue at post but has no usb pluged in. please help me decifer this. thanks in advance troy
This is a fix that worked for me, however I cannot tell you why or even feel that I had done anything which would constitue this as a fix. I leave my PC on 24-7 and came in one morning and it was locked up. Couldn't get a video screen, not even reset worked so I threw the power switch on the back of the power supply. Turned the switch back on and pushed the power up button. The MoBo started 1 long and 2 short beeps, repeating. I pushed the reset button and same thing. I again turned the power supply off, then on again and same thing with the beeps. So this time I turned the power supply off then also un-plugged the power cord to the power supply. I left it that way for maybe 10 minutes, while I did a few other things. I plugged the power cord back in, turned the power supply back on and hit the power up button. My PC booted up...no problem. ???
Point is - this issue as reported by others may just be a hardware or bios fluke and needs a power reset or maybe even clearing the bios and restarting. Reseating the memory sticks, use just one memory stick and rotate the memory sticks to sort out the possible bad one and reseating the processor may also help.
Oct 12, 2010 | ASUS M2NPV-VM Motherboard
Motherboard will not post
Turn it off. Remove the AC power-cord.
Disconnect all the devices (floppy, disk-drive, CD-drive).
Remove any add-on PCI cards (modem, network, TV, 2nd video).
Remove ALL the RAM.
Reconnect the power, and turn it on.
Try to POST -- if it is not "dead", it should "beep" a few times, due to having _NO_ RAM installed.
Turn it off.
Add ONE stick of RAM.
Connect the AC power-cord.
Turn it on.
Same "beeps"? Different? No beeps?
Oct 09, 2009 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P5N32-SLI Premium mobo w/ WinXP Pro (SP3). System dead
After doing all of that and nothing has changed, sounds to me like your mobo is bad
Jun 26, 2009 | ASUS AI Lifestyle P5N32-E SLI...
Asus crosshair mobo problem
you need a more powerful power supply
Apr 23, 2009 | ASUS CROSSHAIR Motherboard
No display on my asus P4GE-MX mother board
Is there any beep from the motherboard? First thing that you need to check is the RAM. unplug the power cord and remove the RAM. Now, plug in the power cord and try switching the Comp and see if there is a any sound from Mobo. It should idealy warn you that there is no RAM with continous BEEP. If that happens, the Mobo is fine.... Grab a new RAM and try it out. The system should boot now. (If there was "No RAM warning beeps" when you switched on the system without RAM). There are many issues that may put down the Mobo but in most cases its the RAM that stops functioning... Try this and see if it helps. Please post your result here so that we can see if you need further assistance.
Feb 09, 2009 | ASUS P5PL2 Motherboard
No Video Output.
Try without any RAM and see if there is a beep...if there is then mobo is ok. If no beeps still. Check the CPU. Also check the PSU if its giving adequate power to all the added cards. If possible try with another PSU. Try clearing CMOS as well. If all these doesn't do any good to the mobo, I think its time to RMA the mobo. Have a great day!
Jan 31, 2009 | ASUS M2N-SLI Deluxe Motherboard
Asus P5N-E SLI Mobo will not boot or post.
Hi bart, please re-check you're memory. See page 1-17 in you're user manual. (Read everything)!
You're Asus board can not use 184-pin DDR DIMM's.
Also check the QVL list for supported memory page's 1-18 & 1-19.
I did not see Corsair on either page.
You're board can only use 240-pin DDR2 memory. Please read the "Notes" at the top of page 1-18.
If everything (Regarding memory) is within the Asus specifications than clear the cmos/bios & re-boot again. If you're system still does not boot than remove one DIMM & try again.
Asus warrants their boards for three years. Call Asus tech at
1-812-282-2787 EST, IL 8:00AM to 5:00PM. The call is on you but the service is free. It's worth every dime.
Good Luck & Kind Regards.
Would you be kind enough to let me know what Asus suggested? (If it comes to that).
Mike
May 15, 2008 | ASUS P5NSLI (0610839134670) Motherboard
New asus mother board, no display
Do you get a POST beep? If not, then it is possible you ended up with a dead mobo... manufacturing defects do happen, and ASUS will be happy to replace it for you (they're quite good with it, actually).
If you do get a beep code, could you please post what it is?
Dec 24, 2007 | ASUS P5P800S Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Open Questions:
See all ASUS P4R800VM MOTHERBOARD P4/SOCKET478/MATX/4GB Questions
Computers & Internet Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
