Question about Saws
Where is the lock button for the skill saw circular saw model 5150. were trying to get the blade back on and the motor just turns when we turn the screw?
  • David Ford
    David Ford May 11, 2010
    I checked a couple sites and I dont see any lock button. What did you use when you removed the blade? All is not lost though when you try and tighted the blade just put the blade against a block of wood to stop the rotation and tighten the bolt.
  • gopinathan May 31, 2013
    sir u dont unterstand my question .i will ask this ,skill saw 5500 armatur frond position bearing model nomper pls ask my qustion.
    President:
  • 1,996 Answers
I can't seem to access the parts view for your model, because of its age.
But I'm thinking skil probably hasn't changed things all that much.
Take a look at the 5450 and see if this doesn't help any...click here ...and scroll to page 7.
Posted on Apr 10, 2009
I've borrowed a circular saw (v old B+D 1 HP model). Can't loosen spindle bolt to remove blade: the blade is locked with a pair of locking pliers against the guard, but when I turn the spindle bolt...
you just have to look for little button close to blade, smash it, hold it while you move the blabe till gets stuck then you're ready to loose the blade! hope this help
Jul 24, 2011 | Saws
How do I replace the blade on a Skill saw circular blade? The blade keeps turning. Is there a locking mechanism?
on most of the new saws there is a button that you push in to lock the blade, you have to hold down on the button and tighten blade.after you release button turn the blade to make sure the lock released befor you hit the trigger
Jun 28, 2010 | Saws
How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Jun 07, 2010 | Skil Saws
Blade change skilsaw 5150
The locking button on this saw is designed for safety. If you are attempting to change the blade it should NOT be plugged in. It sounds as if someone has pushed the lock button while the motor was running and sheared it off.
The only tool that is required to change the blade is the supplied wrench or an equivalent box end. If you cannot make the repair yourself for have the equipment repaired you can take a pair of vise grips. (Use cardboard to prevent warping or gouging the blade) and clamp the edge of the blade below the teeth. The vise grips will stop at the front of the saw as it is too large to pass by the guard allowing you to loosen the nut. Clamp the new blade in the same way only the back of the saw will be used to tighten.
I highly recommend that you either repair yourself or have the tool repaired by a professional.
Parts schematics are all over the net for this tool, here is an example:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/skil/5150
As you can see most of the mechanical parts are only a few dollars and it could save you from serious injury during operation.
Feb 13, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
Have an old Black and Decker 7321 Skill Saw. Bought it used. Cant figure out how to change the blade. Help
With the saw UNPLUGGED, check around the base of the motor shaft, there should be some kind of button that you can depress to lock the blade from turning. Then with the appropriate sized wrench, turn the blade locking bolt clockwise (it is a backward thread) to loosen it. Then simply remove the washers, etc carefully and replace them the same way they came off. If there is no locking button, you can use a scrap piece of wood on the saw table and push down on the blade to lock it in place.
Aug 08, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Where is blade lock for my Skilsaw 5150 located
look for the button on the right side of the handle. Other models require you to put a phillips head screwdriver into a hole in the blade to hold it against the body of the saw.
Jul 13, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Where is the blade lock button on a skilsaw 5150 2 1/8hp ???? i can't get the blade off and turning the saw bolt the same direction as it spins isn't working.
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Jun 25, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Just bought Skill Saw 5150 with no blade and bought a 7 1/2'' blade and the saw has a wrench but can't find anyway to lock to undo the nut so I can replace the blade. I pulled on trigger and held it but...
hello I can help you. Look carefully around the housing that surrounds the blade and you will find a small lock button. Push it in and rotate the blade until it locks. Then apply the wrench.
here is the link to the free manual from skil
http://www.skiltools.com/en/CustomerService/PartsListsOwnerManuals/
Jun 17, 2009 | Saws
How do you re-install the Skillsaw 5150 blade?
I,ve personally never heard of a problem quite like yours. I use skill saw brand saws every day and the arbor and washer will only make the blade wobble if installed incorrectly. Blades can be turned around to cut different types of material as well. Check to make sure the hole or diamond is the same on the new blade(you might have to punch it out) if its not seeding properly on the saw, you could also check under the guard to make sure nothing is binding the saw. The only other thing I could suggest would be to check the lock button (the one you hold to change blades, that stops the saw motor from turning) if that is stuck, your saw won't run. Good Luck!!
Oct 28, 2008 | Saws
Finding the lock button..changing a circular saw blade? "skill saw brand,usa" cannot seem to find it anywhere
older model of circular saw dont have a spindle lock.wedge the blade on a bench vise & make sure ur not clamping the teeth of the blade & then turn the blade screw clock wise.
Jul 03, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
805 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
