Question about Whirlpool Duet GHW9150P Front Load Washer
Front loader washing machine not spinning
How do I find out what is stopping the spinner to work?
I cleaned out the filter which had coins and gunk stuck in it.
Iinitially it didn't make much difference but eventually the spinner kicked in.
incidently, I looked at another site while I was waiting for a response from Fixya, which provided a list of potential causes and fortunately it turned out to be the first one.
Thanks for responding - I may indeed use your service in the future as I'm sure something else will stop working in due course. Bill
Posted on Mar 07, 2009
Samsung washer spinner is not spinning
Model number? Top loader? Front loader? Any error messages? Is it doing anything else or is it just dead?
Nov 13, 2016 | Samsung Washing Machines
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
Tub on machine dropped
If we are talking about a front loader it is going to be a broken spinner or bolt holding spinner to tub
Nov 05, 2013 | Amana Washing Machines
Kenmore front loader stopped washing, or spinning
Is it induction or electronic motor,,,,if its electronic it may be carbon brushes,,,if its induction it may be capacitor
Jun 13, 2013 | Kenmore Washing Machines
When you turn the spinner on it wont work i'ts geting power to it but wont spin but pumps the water out
Check that the drive belt is on (you can find this underneath the machine if its a top loader, or in the back if it's a front loader) If the belt is on, check that the pulley turns freely, you may possibly be looking at a seized bearing or gearbox.
Jul 29, 2011 | Washing Machines
My washer had stopped spinning about two weeks ago, we replaced thecoupler and it worked fine but today it stopped spinning again
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Washing Machines
Speed wash will not spin drum to wash clothes
I had the same problem. The pump is not pumping out the water, thus stopping the spin. Take off your pump (located under the washer in the front right) and look inside to see if there is any junk stopping the plastic spinner to spin. Clean out really good along with the attached hoses. Replace (tricky!) and try the washer!
Mar 29, 2010 | GE WSXH208A Front Load Washer
Washing machine not spinning properly
indicates that the suspension rods ( top loader ) or bearing supports ( front loader ) need replacing as the bowl is not level
Jun 24, 2017 | Zanussi F1245W Front Load Washer
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
