Question about Crunch PZi1000.1 Car Audio Amplifier
No sound okay this is really starting to make me mad. I have the crunch 1100 and i have no sound coming from the subs. I have all the wires wired up right. i got new rca thinking that was the problem but still nothing.I tryed a new radio and still nothing the door speakers work fine its just the subs. what do you think i sould try? Anything will help.
  • jason May 11, 2010
    is the remote switch power(power ant. wire on radio) connected from the radio to the remote switch on the amp?
    Scholar:
  • 61 Answers
Hi there
on your CD deck or what ever unit you plugged the RCA wires to needs to be set on subs the radio needs to be set to put sound to your amp.....on your CD player if you press the F/function button a few times it will scroll to SW which is for the subs set this to the on position or if your CD player has a button with SW press it and turn on this feature......if this has been done......check the fuse or fuses on the amp.......if you have done all of the above check the back of the CD unit to make sure you are plugged into sub-woofer RCA or R (rear) RCA ..........sometimes people accidentally put the RCA wires into the aux input RCA,,,,,, double check this.........
hope this helps
Posted on Mar 07, 2009
Mtx thunder 6152 is getting way to hot and shuts its self off when it get really hot
okay, first thing i would do is turn down your gain. Sounds like you are over working the amp thats wire your amp gets hot and shut off, it's going into protection mode. Is your amp enough for your subs. Some times not getting enough power to your amp might do this too. But if your subs wattage is way over your amp watts, you need to upgrade your amp. Also check your subs and see how the are wired up with the ohms, And see if your amp can take a 1 ohm stable load or how ever it's wired up at. hope this was helpfull.
May 13, 2010 | MTX Thunder 6152 Car Audio Amplifier
My amp turns on but the subs don't sound
i am not really sure what your question is. is there any sound coming from your amp at all let me know
May 10, 2010 | Crunch PZi1000.1 Car Audio Amplifier
Speakers aint hitting????
i had the same thing happen to me and turns out my wires on the speaker inside the box popped off. might help
May 06, 2010 | Crunch PZi1000.1 Car Audio Amplifier
Subwoofer wont go off.....vibrates like mad
Sounds like a short circuit, check all connections and check that it will work as set up. Some will only work as a mono(i.e. you use 1 caannel not a combination of both) could also be a loose connection.Also if the head unit is off, the amp for the sub should be off. Is the amp wired to permanant live? If so this will cause this. Wire to electric aerial switch on head unit.( there will be a live wire and a switch wire on amp).
Jun 02, 2009 | Rockford Fosgate Punch Stage P110 S4 Car...
As soon as they turn on there start pumping with or without sound
You have the amp's gain turned up too high and you are getting feedback. Turn down the gain on the amp and you should be fine. If it doesn't go away until a really low volume, you may need to run a dedicated ground wire from the engine groud of your vehicle to the amp, or buy a ground loop isolator from radio shack or somewhere.
Mar 17, 2009 | Kenwood KFC-W2510 Car Subwoofer
Crunch amplifier
there is a bad ground or some other wiring issue in your car you will have to re wire all new to find it unfortunately
Dec 12, 2008 | Kicker KX600.1 Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Amp goes into protect mode.
I would definately suspect wiring. If you can use a volt meter. Put it on the b+ to ground and see what the reading is should be 12+ then try the ground to remote wire should be 12+. If it drops below 12 volts when car starts. Recheck wires for loose connection. Also double check the wire you have the remote wire connected to. You might even want to disconnect from the amplifier and use a jumper wire from the positive terminal on the amp to remote on the amplifier and see if it stays on then. If it stays on you will have to find the loose connection or find a different wire to get remote power.
Feb 05, 2007 | Crunch V-Drive V-2800 Car Audio Amplifier
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Crunch PZi1000.1 Car Audio Amplifier Logo
166 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Tygh Duval
Tygh Duval
Walter Dominguez
Level 1 Expert
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
