FixYa.com
Tags:
IBM DS4500
Cloned system 552 errors on aix 5.1 but not 5.2 on...
By Rogers - usenet poster
We have done extensive testing using EMC srdf to basically clone
rootvg's from running systems to our DR site. The aix 5.2 servers seem
to failover well but on aix 5.1 we get 552 boot errors.
EMC has a 552 error work around that calls for booting into maint mode
, importing the rootvg disk then rmdev the hdisks that have rootvg
defined. Seems with aix 5.1 the odm it pulls in keeps the original
servers hdisk locations which it can't find on the DR hardware, thus it
hangs. The removing of the definitions in maint mode causes it to re
discover the the devices and it boots.
Any ideas what as changed in aix 5.2 that could make this work ?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Ross
Ross - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Not sure if you got my last post, again;
Thanks for the information. How did you modify the ODM for aix 5.2 to
work? I understand the commands but we are worried if we modify the odm
on the source server it will cause a problem ?
We have worked with IBM and just here that bit level copies are not
supported . We are continuing to push IBM .
If you don't mind let me know if there is an easier way to contact and
we can compare notes .
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
I received your mail, and I responded, but it bounced. Mail me
privately with a working address and I'll re-send. Maybe I just can't
send messages to yahoo from gmail.
Thanks.
/cam
Solution #3
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
We had a similar problem (booting from FAStT/DS4500 though Cisco
switches with no persistent FCIDs) and the story we got from IBM is
that there are fixes for this (dynamic tracking) in AIX 5.2 that aren't
in 5.1. We did the same thing you did to recover the systems initially,
but the problem has now been solved. IBM backported these fixes to 5.1
for us (and some other customers); they've been tested and they work.
You can change the scsi_id attribute in the ODM for the fscsi/dac/hdisk
devices and it will discover a new one and continue to boot. There are
some caveats to this, but it works well for the most part. We also
enabled persistent FCIDs in the switches which should have been done in
the first place. You're restoring through different switches so you
need the functionality in the fixes.
root@host:/home/cam# emgr -l
ID STATE LABEL INSTALL TIME ABSTRACT
1 S CFG_HA_51G 08/21/04 06:52:57 Dynamic Tracking and HACMP
fixes
2 S fastt_lib 08/21/04 06:53:58 FAStT libcfgscsi.a for dac
tracking
These were supposed to be released as APARs IY58854 and IY59851, but it
should be noted at at least one of these is a FAStT-specific fix, so
I'd ask IBM or search for an APAR for your particular hardware.
Let me know if you want any further information on the problem, I've
unwittingly become an expert in AIX and FAStTs.
/cam
Can you Help with these Network Storage problems?
Network Storage
telefunken ttv-29tb pincushion
I have the above tv and the... Answer This...
Network Storage
external drive just stopped...
First, Windows warned that a... Answer This...
Network Storage
transferring files from...
I recently purchased the Antec... Answer This...
Network Storage
DNS-323 ACCESSING A NETWORK...
I have made a few attempts in... Answer This...
Network Storage
Trouble with Simple Share 250
posted by Kb2MSE on Jun 24,... Answer This...
Repair Service
Find Network Storage Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
